Question about Philips MDV560VR DVD Player/VCR
Pressing stop for more than 5 sec doesn't change 'progressive scan mode'
I tried to get the Mdv560vr off 'progressive scan mode' by pressing stop button on the unit and the remote without success. Can you please help?
  • smilingdavie Oct 22, 2008
    Your solution worked. I might just add, that in order for it to work, the tray must be empty and only the remote stop button does the job.
    Good job and message so quickly sent to me!
    Genius:
  • 1,269 Answers
Try to turn off the your unit first, unplug the power for about 2 minutes. Then when you turn it back on, hold the stop button for 10 seconds then release.
Posted on Oct 22, 2008
  • 10,594 Answers
Please press and hold STOP button for more then 5 seconds to cancel Progressive Scan mode.
  • Shahid Electronics
    Shahid Electronics Oct 22, 2008
    If above solution doesn't work, check video cord connections.
I have no picture , the progress scan light is on, but i do have sound
It is probably in progressive scan mode - hence why you get no picture. Your TV may not support progressive scan, so you can try the following:
Without a disc inserted, but with player on, press and hold STOP button (on front of unit not remote) for 10 seconds, then release. This should reset the video output of the player back to normal interlace.
I cannot guarantee the success of the outcome, but it seems to be the standard reset solution for this and similar budget priced DVD players.
Fingers crossed that it does not require further action.
Apr 10, 2011 | Sylvania DVC840F
My xbv410 is stuck on progressive scan mode. I
press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
Mar 13, 2010 | Zenith XBV442 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
I have a magnavox mdv56ovr progressive scan dvd/vcr and i can t get it off the progressive scan mode
with the dvd tray empty, press an hold the 'stop' button for 10seconds.
or
'setup', up, up, up, right, up, select
Jun 13, 2009 | Philips MDV560VR DVD Player/VCR
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan mode
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
Progressive scan button is stuck
What progressive scan "button?" On the unit? Remote? In the LCD display? I don't see one....
Nov 19, 2007 | Sylvania DVR90VE DVD Recorder/VCR
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Philips MDV560VR DVD Player/VCR Logo
217 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
