Back to:
Tags:
Sansui VRDVD4001 DVD Player / VCR Combo
Can't get dvd out (by 3 users)
posted by treelo on Jun 13, 2006
The player will not open so I can get dvd out, anyone had this problem. both the button on remote & player itself will only respond with ERR & Incorrect disc. Also won't play. The video part is fine.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 22, 2008
DVD played ok for 3 min, then the picture froze. The incorret disc and error messages came up. I can't remove the DVD or even open the DVD drawer
Thanks for any suggestions.
Comment by Guest, posted on Feb 22, 2008
I accidentally put 2 dvd in the tray. the second one went in, but player did not play. had to take it apart, and screwed it up big time............
Best Solution
posted on Jun 15, 2006
Helpful (85)
silly girl
Rank:Wiz Wiz
Rating: 81%, 3302 votes
Search your manual for "manual open", or some override. Sometimes there is a hole in the bottom of the player that lets you slide a knife in a push the door open a little bit. Should have something written on it, like "emmergency".
I can't say it will work after that though. Sansui no longer makes most of the products marked "sansui", they sold the rights to use the brand name. I think orion makes it's basic level TV and Video equipment, and they tend to break after you take a few steps out of the store.
Hope it works out for you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Can't get dvd out:
I don't want to Accept this solution
Solution #2
posted on Apr 13, 2008
Not Rated (0)
swausa
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I had the same problem With the DVD getting stuck in the player and DVD not playing. I was able to get the DVD out by first removing the screws that secure the top cover of the unit, then remove the cover ,then remove the face plate of the unit, mine had no screws ,it just had tabs that secure the face plate, also you will have to disconnect the serial cable below the DVD tray.Then look under the DVD tray and you will should see a white part that will slid to the right and this will allow you to manually push the DVD tray out and remove the DVD. I got less than a years operation out of the DVD player , the VCR still works though. After freeing my DVD i tried again to play it and the same problem occured. The longevity of this product is just not there for the100 bucks of what i payed for it. INFERIOR PRODUCT
Thank You!
Can you Help with these DVD Players problems?
How do I set the timer record. Didn't work when I tried...
DVD Player without fun,radio, games
Where can I purchase a player with or without recorder for...
Looking for a two digit code for sansui dvd/vcr player to...
Hi, I am getting an 'unusable signal'; message on my...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
