How do you take the front off the Pioneer sd-582 HD monitor so you can get to the lenses to clean them?
  • rigo109 Nov 21, 2008
    I have removed the back and cleaned out the panasonic SD-582 HD rear projection tv but I am having trouble setting the mirror back in and closig it up.
    Got any suggestions on how to reset the mirror and get the back plastic mount back on. Is there a way to remove the front screen from the front? Does it snap on and off? How
  • 905 Answers
You can't get the front off , you have to open the back to get to it or to clean it
Posted on Oct 18, 2008
Pro-710 clean front screen and crt
If the pic on your CRT RPTV is bleary, its front viewscreen is not the problem, and no, your set is not worn out even tho it really looks that way.
The solution is that the internal optics need to be cleaned, due to the high voltage inherent in CRT use. Remember how your old, thick computer monitor would get incredibly dusty on its face? That's because of the HV ionizing all nearby particulates and charging them with static cling. They then drift to and deposit themselves directly upon the closest smooth surface - in the case of CRT computer monitors, the face of the monitor. In the case of CRT RPTVs, the mirror and lenses. In other words, at certain very critical points on your 28 surface optical chain that comprises the CRT RPTV's projection light path.
Optics cleaning should happen once a year without fail, otherwise you're really not getting your money's worth out of your multi-thousand dollar set. And CRT HD ready RPTVs are classics, with 20 year service lives.
On some units only 4 surfaces need to be cleaned, like Mit. On others, like Pioneer, 10 of the 28 surfaces need to be cleaned.
But be very careful, these lens surfaces are made of very soft, vulnerable plastic, and are very easily scratched or - even worse - scuffed, which is thousands to tiny scratches at once. The mirrors in HDready sets are front surface or mylar - you are not cleaning glass at any point, with these sets.
As such you need to be painfully careful, as damage is immediate and permanent. I recommend contacting me directly before doing any optics cleaning on any projection set, esp. CRT RPTVs.
But oh, what a difference a day makes! This can all be done in a day, after which your CRT RPTV will look like a new TV again!
Jan 14, 2012 | Pioneer PRO-710HD 64" Rear Projection...
try to open the back of your tv but be sure to unplug it then clean the projector lens using a dry cloth cotton.
Oct 15, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
How do i clean the projection screen and projector.
unscrew the back off and there should be 3 lenses, get a microcloth from the dollar store and some rubbing alc and wipe the lenses and then you can wipe the mirror and inside screen. just dont touch the bottom electrical panels or tubes they carry an electrical current.
Jan 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
My pioneer sd-533hd5 is 8-9 years old. how do i clean the lanses?
You should be able to access it from the back panel. After you remove the panel, the lenses should be mounted on a platform. If you are careful, you can manuever yourself in far enough to clean the inside of the display screen. Good luck!
Nov 02, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer sd-m1407 has a poor picture
Start out resolder all poor connections on power supply board all pinns on FBT see what happens after you do this! Also clean mirror and top of tubes lenses .
Feb 16, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-643HD5 HD set up
Yes a simple cable will do it. Look for a converter designed to display a computer vga on an HDMI jack. I have one, and would expect it to work in reverse. My cable has a male VGA like a computer monitor cable.
Oct 22, 2008 | Pioneer SD-643HD5 64" Rear Projection...
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Black levels off
My quick and easy solution was to clean the dust off the lenses of each CRT.
1) Unplug TV
2) Remove the back panel.
3) Wipe each of the three (plastic!) lenses lightly, with a lint-free microfiber lens cloth. Do not use anything that might scratch the plastic lenses.
Other than that, you'll need to hire someone to adjust your gray scale tracking.
Sep 27, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-P5185-K
pull off speaker grill on fron( held on by velcro )t. then look for screws beneath the screen. remove screws and pull bottom of screen bezel out and lift up. remove screen and clean lenses and mirror
May 30, 2008 | Proscan PS32500 32" TV
Pioneer SD-P40
Check to see if Q118 is shorted on video/defl pc
Aug 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
