Question about Nintendo Wii Console
Video is black and white
When hooking my wii to my main tv which has satelite, dvd and surround sound hooked to it the video is in black and white, whether hooked through the surround sound or directly to the tv. It works fine hooked to my other tv which has satelite and dvd hooked to it. I've been told it's because of the surround sound. But why and what's the solution?
    Problem Solver:
U cant have two audio plugs hooked up at the same time in the same location,hook the wii up to a anthother location on that tv.\
Posted on Dec 30, 2011
When I hook my wii up the picture is in B&W / I have a sharp 42"
tv with an antenna I have a DVD hooked up also that is fine
Posted on Feb 12, 2009
  • 4,402 Answers
Are you using the same SCART socket that you use for your other consoles or a different one? My SCART3 input on my Panasonic telly has two different modes - one which displays in colour, and one which displays in a sort of grainy black n' white. There is a purpose to it but I can't remember what it is. :-)
Anyway, you switch between the two by pushing the AV button and then hitting the colour button which corresponds to SCART3 a few times 'til you reach the correct setting.
It probably isn't that, but... y'know. Sanity check.
Tune your tele and check you've got it on the right PAL/NTSC setting.
Posted on Oct 24, 2008
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
Dec 30, 2009 | Nintendo Wii Console
I can't get my Playstation 2 or Wii to work with Vizio tv
I bought a RF Switcher Phillips SWS2325W/17 ...with this I was able to hook up my Wii...TV...DVD...and fine...hope this helps
Dec 23, 2009 | Vizio Televison & Video
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
I have no color
Are you using the default video cable (Red, White, Yellow) for video and sound? Make sure the Red and White are connected to the audio in for video 2 and that the yellow is connected to the video in for video 2. It might also be labeled composite video on your TV. If you are using the Red/Green/Blue plugs labeled component or Y/Pb/Pr then that might your problem with the black and white video.
As for the controller sync problem, you should press the red button next to the SD card slot on the Wii and the red button under the battery door of the new Wii remote in order to sync the two.
Mar 30, 2009 | Nintendo Wii Console
How to hook up wii to surround sound
Put all the wires to the tv. Now you need another A\V cable (yellow, red, white) only use red and white from, audio out on tv to audio in on surround system and set it to TV. OR Put the red and white from Wii to surround system and the yellow to the tv. this way you have to use surround to hear it. The other way you can use the tv or both. The first way is ideal if you have an extra cable.
Mar 15, 2009 | Nintendo Wii Console
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Mar 15, 2009 | 2006 Chevrolet Uplander
Hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Dec 26, 2007 | Nintendo Wii Console
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Nintendo Wii Console Logo
537 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
