Question about GE WBB4500EWW Top Load Washer
Fill will not stop
The machine keeps filling up, still fills up while it is washing. The water will overflow if you have it on medium or large wash. It will stop filling when the wash cycle is done and starts draining.
  • Anonymous Feb 08, 2009
    When I use large load cycle, during RINSE cycle, it will not stop filling the water.
    Works fine in Medium load cycle.
    Occasionally, "LARGE" cycle works properly.
    Sergeant:
  • 220 Answers
To save your self, water presure swich vecium hose valve control,and3th drive belt is the most comon promblems for mall fuction.
Posted on Aug 08, 2012
  • 958 Answers
You may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
My washing machine wont stop filling up with
well the part that tells the water to stop running in is the pressure switch if the water valve is working properly so disconnect the power and if the water continues to run in it is the water valve just replace it
Apr 26, 2010 | Washing Machines
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Washing machine trouble
You need to replace the water level selector switch. You can check the part at repairclinic.com
Jun 27, 2008 | Washing Machines
Our washing machine keeps filling with water and overflows. It will not stop filling with water no matter what setting it is on.
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Apr 26, 2008 | Washing Machines
Over filling
pressure switch pipe is either blocked or damaged, the weight of the water pushes air up the pipe to activate the switch to stop the water filling, for some reason its not doing so,
this is a small thin pipe that goes from a point in the machine low down, to a little round flat object (normally) up near the top of the machine inside up near the top
drain the machine and clear out the pipe at the bottom where it joins  the drum or whatever, make sure joints are made good
if i have helped please rate me
Oct 10, 2007 | Kenmore 88732 Top Load Stacked Washer /...
GE WBB4500EWW Top Load Washer Logo
590 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
