NetGear WGT624 Wireless Router Logo
J More Posted on Jan 28, 2012
We have multiple wireless laptops, wifi enabled phones and wifi enabled game system, my old router seems to be going out so I need to get a new one. Any suggestions on what would be good for a home with multiple wifi items
andrewdai
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Jan 28, 2012
andrewdai
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
5432
Points
58
Linksys router is the best, get the dual band, good for gaming and wifi network. also it security is way better than other router. it made from cisco, is a trust brand.
http://homestore.cisco.com/en-us/products/linksys_stcVVcatId551966VVviewcat.htm?icid=Wireless-Homepage-all-linksys-products-routers-image
Cwrdigitalmedia
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Sep 13, 2014
Cwrdigitalmedia
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
0
Helped
2810
Points
16
Dual band routers have a better range and bandwidth capabilities.
How do I enable the wireless internet connection in my laptop? brand is fujitsu fmv lifebook#FMV-E8250?
go to control panel, click on internet connection click on establish find the wifi system in use then enter the code for the wifi system and it connects
1helpful
Where to set up the DMZ for a linsys wifi router Wrt54gsV7.2
To enable DMZ in Linksys wifi router follow the steps below:
  1. Access the router's web-based setup page. For instructions, click here.
  2. Click on Applications & Gaming.
  3. Click DMZ.
  4. Select Enabled and set the Source IP Address and Destination.
  5. Click to apply your changes. The DMZ feature of your router is now successfully enabled.
IPhone connects to wifi if I am close. If I go to another room the wifi falls off. Could it be my battery or something else
It could be your wireless router also. In some cases, the router's signal isn't strong enough to reach to multiple rooms.
If your photo battery seems fine, then I would begin troubleshooting the wireless router.
Hope that helps!
Jul 01, 2013 • iPhone Apps
2answers
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
How 2 connect psp go 2 net via home network and mobile wireless do i need wireless router
to connect your psp go to the internet you need a wireless router to emit a wifi signal to connect to the psp, if you are using you phone as a router connect it via bluetooth.
Yes you need a wireless router or a blueooth enabled phone.
I have a new laptop with wireless at home. How do I set up the wireless connection from my zonet router? Victor
By default, wireless routers always broadcast wifi signal. The only thing you need to do is to enable the wifi radio receiver of your laptop. To do it, make sure that you have the wifi LED lit in your laptop which means that your wifi receiver is ON. Now, you need to connect your modem to your router so that your router will then broadcast internet signal. Then you are good to go. Your laptop should get connected automatically and receive internet signal.
If you want to configure your router, visit http://192.168.1.1 when you are connected to the network so that you can change some of your router's behavior.
Wireless router not working wirelessly
First of all,check the DHCP option in wireless router.If its enable then go to remote user whether PC or laptop enable the DHCP option.
Defaultly laptop have wireless adapter.But IN system doesnot have.SO you need to buy a new wireless adapter..
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
1helpful
3answers
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
2answers
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
