Question about Sony RDR-GX315 DVD Recorder
Sound but no picture
I just bought this and upon hooking it up, i get sound but no picture... i have 2 seconds of picture until the progressive button lights up in the corner of the dvd burner... is there a way to shut that off so i can see the picture, or does that have anything to do with it?
  • 513 Answers
Apparently your TV doesn't support the progressive mode (480p). You should be able to turn it off by pressing the pause button on the recorder for about 5 seconds, untill it turns off I guess. Hope it works
Posted on Jun 15, 2006
Press the Pause button on the DVDR unit (not using the remote control) for about 5-10 seconds. This will remove progressive scan.
Posted on Oct 20, 2007
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
My PS3 is two years old. I have it hooked up to a 1080P via HDMI. I cannot see the picture but am able to hear sound.
try the 1080i hd setting (p is for a progressive system which is still in the testing/developmental stage) and that should fix your video problem
Dec 23, 2010 | Video Game Consoles & Games
Hook up the composite cables that come with the unit. Turn the TV on to the correct input. Turn the PS3 on using the power button on the unit. When you press the button continue holding the button until you hear a second beep....about five seconds. That should set the PS3 back to the factory output. If that corrects the problem you can set the PS3 to use whichever cable you want via the XMB.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound on my tv when hooking up my av cables
Ok
switch the power switch on then wait til the red light comes on..
the push and hold the power button until you hear it beep it should reset itself and sync up! may take 5-10 times
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
I'm stuck in Prggressive Mode on my RDR-VX515
pressing and holding the PAUSE button on the front of the DVD player for 5 seconds. (this is the one that worked for me) Hurray!
pressing the PROGRESSIVE button on the front of the DVD player or P.SCAN button on the remote control to disable the progressive signal.
power off the DVD player and press 369 using the number buttons on the remote control, then power back on the DVD player.
moving the VIDEO OUT switch on the back of the DVD player to the INTERLACED position.
Dec 11, 2006 | Sony RDR-VX515 DVD Recorder/VCR
Sony RDR-GX315 DVD Recorder Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
