Question about Zyxel P660HW-D1 Router
SAME PROBLEM WITH MY PS3
I CANT CHANGE MY NAT SETTINGS ON MY ROUTER. TO PLAY MADDEN. NOT COMP SAVY AT ALL
  • Zyxel Master
  • 6,487 Answers
You can follow the steps from this link so the NAT will be open for your Madden http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/Madden_NFL_07.htm
Posted on Oct 19, 2008
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I play on xbox live, i cant play with some of my friends because, it says somthing bout my Nat settings is strict can i change this and how.
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jan 23, 2011 | Belkin (F5D8231-4) Wireless Router...
Hi i would like to change the NAT settings for my PS3 i have a st585v6 router how can i do this. the ps3 is not wireless
hello,
To change the NAT settings you need to open ports on the router. For that
1)Get the TCP/UDP ports from PS3 vendor
2)Get the IP add of your PS3
3)Log into the router interface and open ports for it.
Hope this helped.
Jan 21, 2011 | Computers & Internet
My NAT is set to moderate and i cant play xbox live off it. it says i have to open my NAT. how do i do that?
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Jan 02, 2011 | Linksys Wireless-G WRT54G Router
How to change the nat settings on my belkin play router from strict to open so i can play the ps3 online gameplay more easily.
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
Jul 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
XBOX 360 Wireless Adapter Question
When i try to play halo3 with my friends i get the same problem. I cant connect to them and sometimes i also cant hear some people talk. Some problems might be that your NAT is set to STRICT or MODERATE you will want it to be open to play with your friends. I dont really have an answer but you will need to get in your apartments router to change the settings to get the NAT to become open. If you type in on the google search bar: Cant connect to friends on xbox live there will be some answers for this problem.
Jan 14, 2009 | Microsoft Wireless Network Adapter Xbox...
Ps3 is on nat setting 3 strict
You need to forward a port for gaming. Call Sony and ask them what port should you open. Or go to www.portforward.com if you wanna know what port would you like to open
May 15, 2008 | Computers & Internet
Zyxel P660HW-D1 Router Logo
144 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
