Question about Hitachi 53UWX10B 53" Rear Projection Television
Power I have run across this problem 3 times, and solved it the first 2 times by luck, but can't solve it this time. The problem is that when I turn off the power, the picture goes off, but the power light doesn't. It is happening no matter which input I am using, antenna or vid 1 through 5. How can I reset the power so it will go all the way off?
    President:
  • 3,130 Answers
What did you do to solve the problem the first two times as you stated? ok if the light isent going off when the set is that just means that the main relay or power may not be shutting down but the microprocessor is or could even be visa Versa?? Im not there to see the set. Its not a user serviceable thing that you as a consumer can service unless youve had exstinsive training in consumer electronic stuff.. These things are not for the handi-person to tinker with as first off they are expensive pieces of equipment. second is that they do have very very high voltages inside them even when they are unplugged and off for a long time. to service this set your gonna need the experience as well as a service manual and also some special equipment to work on these sets.. The manufacturer as well as the UL peeps state that there are no user serviceable parts inside this type of set.. Sorry but your gonna have to seek a pro to assit ya. Good luck.
Posted on Jun 13, 2006
How to solve canon np7161 error code 104
To clear E000 through E004, operate as follows:
1) Select '412' (clear E000-E004) in service mode.
• The copier's control panel indicates the respective error code.
2) Press the Start key.
3) The copier will automatically turn off, clearing the error.
E004
• The triac has a short circuit.
• The DC controller PCB is faulty.
Fixing heater (H1)
=Execute service mode '412' (error clear) to clear E004.
Turn off/Turn on the power switch. Does the fixing heater turn on?
Triac
=Check/Replace the power supply PCB
DC controller PCB=Check the wiring from the power supply PCB to the DC controller PCB
The fixing heater fails to turn on.
Thermal switch (TSW1
Turn off the power switch, and remove the fixing assembly. Set the meter range to
"Wx1." Does the meter index swing when the probes are connected across both terminals of the thermal switch
Fixing heater (H1)
Turn off the power switch, and remove the fixing assembly. Is there continuity when probes are connected across both terminals of the fixing heater
DC controller PCB
Set the meter range to 30 VDC, and connect the probes to J106-21 (+) and J105-4 (-) on
the DC controller PCB. Is the resistance about 5 V
Using Service Mode
1) Press the User Mode key.
2) Press '2' and '8' of the keypad at the same time. (Hold them down for 0.5 sec or more.)
3) Press the User Mode key once again.
Feb 27, 2018 | Canon Office Equipment & Supplies
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
The Ink Waste Absorber pads are full. How can I reset? Thanks
Hi! here your solution... to solve your printer problem follow the instruction step by step... 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal. good luck
Sep 07, 2011 | Canon i860 InkJet Photo Printer
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
try to reset it by removing the batery and the power cord an pressing for 30 sec the power button; if is not working maibe you have la faulty LCD inverter and msut be changed.
Apr 29, 2011 | Computers & Internet
I have Nokia 3110c the problem is battery is full but i Swich on the fone 2 or 3 time blinking and turn off
if it helps vote itfollow these steps:
1) remove the back case 2) press the power on button 3) remove the battery (button still pressed) 4) insert the battery (button still pressed)
repeat 2-3 times, this will solve the issue...
if it helps vote it
Jan 16, 2011 | Nokia 3110 Cellular Phone
I have black lines approx. every 2 inches running horizontally across my paper. it just started yesterday. the lines are about 1" wide
Remove cartridge and shake horizontaly couple of times. This will settle toner evenly.
pls. vote for better sharing...thank you and good luck
Nov 23, 2010 | HP LaserJet 1320 Printer
Have a deskjet 710c inkjet printer the inks seem to be stuck over to the right and the 2 orange buttons are blinking. ... * Solve It! Solve It! Bid * * * ... have a deskjet...
I found this on the HP website. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09179&cc=us&lc=en&dlc=en&product=59307&tmp_track_link=ot_search
POWER light On c00106963.jpg RESUME light Blinking c00106965.jpg PRINT CARTRIDGE light Blinking c00106961.jpg Problem
The BANNER lever needs adjusting.
Solution
1. Turn the printer off.
2. Move the BANNER lever (next to the paper tray) up and down a few times.
3. Turn the printer on.
If these solutions did not fix the problem, have the printer serviced.
Oct 27, 2010 | HP DeskJet 710c InkJet Printer
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Pixma 145 is regulerly showing E 2 8 ERROR. i bought it 3 month before. please solve the problem...
E28 is ink cartridge temperature rise error
Try to reset the printer like this:
With the printer powered off but connected to a power source , you must:
1. Press stop/reset button, and then press [ON/OFF] button to restart
2. Press [ON/OFF] again and then press twice the stop/reset button.
3. Press [ON/OFF] & Stop/reset button together, this time to enter the repair status and power lights will be green,
4. Press stop/reset button 4x and warning lights will be go out in [ON/OFF]button.
5. Turn off the printer.( it must be turn off) and then turn it on again.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 Unplug cable power.
Aug 25, 2009 | Office Equipment & Supplies
Set the combination lock on the driver door of 1999 Ford Explorer
check your car manuel and it should tell you to solve both
Jun 09, 2009 | 1999 Ford Explorer
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
