Question about Skype IM
Skype failure to launch
This morning when I tried to launch Skype by clicking on the desktop icon I got the message failed to launch because of another instance of skype in use. I am not sure what this meant, or how to correct it. I restarted my computer and it worked fine. What happened? I have been staying in touch with my wife who is traveling in Europe and we set up times to make contact and the failure to launch makes it difficult to contact her. Any advice to keep it from happening again or what it was would be appreciated.
When i m entering my username in my mobile then skype doesn't work but it work with the same username in my computer.so i m geeting what the problem so please give me the solution..
Posted on Oct 24, 2008
    Problem Solver:
  • 5 Answers
It seems that Skype execution have failed but the process was still in the memory running.
When you did restart your system this process have been erased and you can use skype again normally.
Posted on Oct 21, 2008
Why nobody hear me on skype
turn your speaker on .,works for me every time I keep my speaker turned off all the time .
Sep 07, 2014 | SKYPE Computers & Internet
I want to creat new skype id
I got your answer from: https://support.skype.com/en-us/faq/FA829/How-can-I-run-two-Skype-accounts-on-the-same-computer
In order to use more than one Skype account on the same computer at the same time you need to start a new instance of Skype:
  1. From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
  2. In the Run window, enter the following command (include the quotes) and press OK:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get any error messages, please copy and paste the exact command from this email and try again.
Please keep in mind that if you have changed the installation path for Skype then you need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
  1. Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
  2. Right click on it and choose: Send to > Desktop (create shortcut)
  3. Locate the shortcut on the desktop, then right-click on it and choose Properties
  4. In the Target field, add: /secondary. The Target field should now be: "C:\Program Files\Skype\Phone\Skype.exe" /secondary
  5. Click OK. You can now start a new instance of Skype every time you double-click on the new shortcut.
For Skype 3.8 and earlier Requirements: Windows XP, Two Skype User accounts
First, create a new Windows user by going to the Control Panel and clicking on User Accounts. Choose Create a new account and follow the steps to set permissions. We also suggest setting a password for the new user by clicking on the newly created user and choosing the Set Password option. The new user will also require admin rights on your PC.
Next, create a shortcut to Skype or make a copy of the shortcut that is already in the Start menu. Right-click this new shortcut and choose Properties. On the bottom of the first page there is a button labelled Advanced... . Click this button and select Run with different credentials. Select OK, and then select OK again to close the Properties dialog.
You're all set. Whenever you use this new shortcut it will ask for a Windows username and password. Enter the Skype Name and password of the user you created earlier by choosing The following user: option. Click OK and you'll have a second instance of Skype. It will require that you sign in with your Skype Name and password the first time.
To help automate the Run as trick you can create a second desktop icon for Skype and modify its properties. Click the Advanced button and check the box Run with different credentials. After clicking on the modified icon it will ask you to sign in as another user. Changing the icon graphic also helps ensure you click on the correct icon.
If you have multiple USB headsets or USB Phones you should be able to set up both instances of Skype to use a different sound device.
Dec 02, 2011 | Skype IM
Hi I am trying to download skype 5.5 free version and it is not going past skypetm -Install window.. I hv tried to wait for almost an hour but nothing has worked so far.. Will appreciate help solving the...
Maybe you need some hard disk space and Skype requires at least 256 MB of RAM and 18 MB of free hard-disk space for installation files. Try to delete some of your files that are not necessary especially images. To find out how much free disk space is on your computer:
  • Open your "My Computer" folder by clicking the icon on your desktop. If you do not have a shortcut on your desktop, open your "Start" menu and right-click on the "My Computer" icon.
  • 2 Right-click on your hard drive icon. Generally, the hard drive is named the C: drive. Select the "Properties" option from the drop-down menu.
  • 3 Read the pie chart and accompanying information to determine how much free disk space your hard drive has. Windows operating systems use blue to indicate how much disk space you are using and purple to depict how much free space is available.
  • If you have enough space, try to download SKYPE
    If this would help you please don't forget to give rating.
    Thank you for using FixYa. : )
    Sep 12, 2011 | Skype IM
    Hi my husband has skype set up on our lap top. Can i set it up too? Do i have to download it again or is there a way i can do it through the desktop icon?
    You want a second account, for yourself? If your Skype logs in automatically when you start it... See the menu in top of the window? Go to Skype and select Sign Out. Then you will see the Skype welcome screen and the option to create a new account. Does that answer your question?
    Sep 05, 2011 | Skype IM
    I cant open skype....what do i do
    Try one of the following methods:
    1) Restart your computer and try to launch it again.
    2) Click on the "Start" button and click "Run" (or press the windows button and press "R" at the same time), then type "skype.exe" without the inverted commas.
    3) Uninstall Skype, then download the latest version of Skype and re-install it.
    Thank you for using FixYa! Have a great day and please remember to rate this solution.
    Best regards,
    BearWeb
    Jan 06, 2011 | Skype IM
    My Skype disappeared
    Do you mean, you've uninstalled it? or was the icon lost from desktop?
    First open "My Computer", then "C:" drive and again "All Programs" and locate a folder with the name "Skype" open it and again open the "Phone" folder, double-click the "Skype" icon you find there, if you want it to shown again on the desktop, right click, "Send to" and then "Desktop(Create shortcut)" it, close the window, now it should be there on the desktop. You can run it by clicking it again.
    If you can't find it anywhere, you better reinstall it. Click here and download the skype, and after it's downloaded, run the program. You are done with it, all your contacts and IM's will be intact, there's nothing to worry about.
    If you need further help, let me know with more details.
    Good luck.
    Thanks for using FixYa.
    Sep 21, 2010 | Skype IM
    My yahoo messager will not load when u click on it from the starst menu. i uninstalled the messager and downloaded the latest version and installed it. now when i click on the start menu for messager or...
    Try this:
    Using explorer go to the c:\Program Files\Yahoo Messenger (or whatever you named it) directory + right click on the program icon (EXE file) + send to + Desktop.
    Than delete the old icon as it doesn't work anymore.
    Mar 02, 2009 | Dell Latitude D600 Notebook
    Problem opening quarkxpress on g4 mac
    The first place to look is your permissions. Open your utilities folder in your applications folder and launch **** utility. Click on your hard drive icon and click the repair disk permissions button. It may take a few moments to run. That might solve your problem.
    If that does not solve the problem. Open library/preferences/Quark. Move the pref' doc in that folder onto you desktop (don't trash yet) try relaunching the app. If still not working trash the pref' and try again.
    If all that fails I'm afraid you'll have to re-install the app'
    Sep 28, 2008 | Apple iMac G4 Desktop
    Skype IM Logo
    182 people viewed this question
    Top SKYPE Computers & Internet Experts
    Mike
    LP
    Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
