Question about ViewSonic NextVision N2010 20 in. LCD Television
Menu locked How do I unlock the menu on the tv?
Press and hold both volume buttons on the TV set. Menu Unlocking will appear on the screen. Release the buttons.
Posted on Dec 23, 2008
My fca is lock on my tv how do i get it off
Hello
You must have its original remote control handset to unlock the FPA lock. If you haven't one with you now, try to muy a new one, or get it gathered from any of your friends or relatives who owns the same modle RCA tv; just to unlock the FPA lcok of your TV. After unlock, you can use any remote control to operate it. To unlock the FPA lock try the folloing porcedures. One amoung it will surely unlock your TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA TruFlat 27F520T 27" TV
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
Main menu locked om dell w2306c
Use the side panel buttons to unlock the TV Menu and side panel buttons:
  1. Press the Menu button.
A message appears stating that the TV Menu and buttons are locked.
2.While the message is on the screen, press the volume decrease and channel up buttons on the side panel simultaneously. A message appears stating that the TV Menu and buttons are unlocked.
GOOD LUCK AND PLEASE RATE THIS POST!!!
May 09, 2011 | Televison & Video
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
Seem like tv as lock on. rca tube flat screen
Hello
To unlock your RCA tv do the following. One amoung the method decrbed here will surely unlock your TV. I thinks that you have its orginal remote control with you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 04, 2011 | RCA TruFlat 27F520T 27" TV
Not seen the first six channels
Hello
Reset your TV by following any of the method that works with it. It will unlock your tV, in all respect, including parential lock, tuning lock etc. You have to reset and retune it afterwards.
)K.
Mar 01, 2011 | RCA F19421 19" TV
How do i get my tv off of fpa lock
Hello
Your TV has locked I thinks. Do the folloing and see if it works. This process can unlocka your RCA tv. You have to reset it V-chio after unlock.
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model the processs mentioned above may differ. You have to go all these, till your TV gets unlocked.
OK.
Dec 03, 2010 | RCA 14F512T 14" TV
Hisense tv on "lock"
If you have the original remote with the "CCL" Child Lock it unlocks it. If you are like me and lost the remote I unlocked mine by 1. Turn on TV 2. Hold down the menu button and unplu it. 3. Continue to hold the menu button down while you plug it back in. Mine unlocked, good luck.
Paula
Sep 06, 2008 | Hisense Televison & Video
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
HISENCE PLASMA TV OSD LOCKED
ok any one with the problem having a lock osd on the hisense plasma screen this is what you need to do to unlock the osd
you will need the tv remote control to hand ....
press the menu button on the side of the tv .. you will have a display message saying osd locked ......
now press the menu button again so the same message comes up again then press the number 9 on you original remote for the tv ...
job done osd now unlocked....... hope this helps
you can only unlock the osd with the tv remote there is no other way, so if you dont have one you will need to get one to do this.
Dec 20, 2007 | Hisense TA42P40M 42 in. Plasma Television
ViewSonic NextVision N2010 20 in. LCD Television Logo
425 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
