Question about Compaq Computers & Internet
Can not get a wireless connection - Compaq Computers & Internet
    Genius:
  • 1,124 Answers
Did you check the settings?
Are your wireless router working?
Your wireless card is well configured?
Did you see any wireless network available?
This will be helping you out:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Let me know how it is going
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
Tip
Enable WZC (Wireless Zero Configuration) and connect to wireless network on...
Windows XP has built in wireless utility which can be used to connect to the wireless network. Though, you can still use the wireless utility software that came with the wireless adapter. Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
7. Highlight thee SSID from the list that you want to connect to.
9. You should have successfully established a wireless network connection.
These steps will help enable wireless zero configuration on your XP wireless computer and you can connect to your wireless network using it.
on Feb 13, 2010 | Microsoft Windows XP Professional SP2
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
Can not connect to network
Connecting to a Wireless Network Using Linksys Wireless Manager Article ID: 17673
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
Nov 04, 2010 | Linksys WRT160N Wireless Router
Cant connect to wireless away from home
You have to manually connect to your University's wireless connection. Double 9maybe single) click the wireless icon bottom right screen and then untick the box for connect automatically under your home connection. Then double click on the wireless connection that you would like to connect to from the list of available wireless networks.
Jan 31, 2010 | Advent Netbook
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Wireless connection
hi,
welcome to fixya.com
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
How do i use my built in wireless connection to connect to the internet,please.
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
