Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Kenmore electric Range 2005
What does the errror code F30 mean??
  • Anonymous Oct 30, 2008
    when i turn the oven on all i get is f 30
  • isaura Jan 07, 2009
    I also have the same problem it's either f30 or f10
It means there is a short in your digital clock and it will only get worse. It happens on Amanas, Maytags, etc. GOOD LUCK!
Posted on Oct 19, 2008
The electric range is a Kenmore model
Bad oven temperature sensor.
Sep 02, 2014 | Kitchen Ranges
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
Kenmore model #790-9642440A and getting a F30 alert.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Oct 04, 2011 | Kenmore 96422 / 96424 / 96429 Electric...
Have a Kenmore Electric Range Model- 790.4671. Ran the self cleaning program. Error occurred at the end of cycle. F10 and F30. Oven will not unlock. Show oven locked and a picture of a lock. Oven is...
Sorry to read about your problem
Your F10 code means Runaway Temperature and f30 means open probe connection. try this and see problem comes back.
1. Unplug the unit or turn the circuit breaker off for 60 seconds.
2. Now, restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
3. Check to see if the error code is still displayed on the range.
Note: General information for resolution to this problem, is based on information provided in question. Contact certified technician if problem persist. Sears Repair 1-800-469-4663
I have tried to help you.Pleas help me by Vote/Rate my response. Thanks.
If you are in the Denver,Co area I can help you out.
Dec 20, 2010 | Kenmore 46713 Stainless Steel Electric...
I have a Kenmore Elite slide in range. The stovetop works fine along with the twist knobs. But the touchpad buttons and the oven doesn't work at all. When i tried unpluging it to reset it, it flashes an...
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
Dec 27, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here:
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
we are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
Nov 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
160 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
