My new HP Officejet J4550 All-in-one printer has the following selections I cannot pull up to print: 1. Fit to page 2. Decrease/Increase(percentage) 3. Lighter/darker
  • Puneet Jain
    Puneet Jain May 11, 2010
    This is very unusal and strange.
    Could you please let me know if the printer print any thing during these command or just stop print.
    Any error message Display/coming up on PC or printer.
    Regards,
    Ellin
    Guru:
  • 558 Answers
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Check printer setting from the Control panel, select the right printer and in the window go for Test Page, also reset the setting to default.
Posted on Oct 20, 2008
OfficeJet 4315. When receiving faxes, why does it print blank pages?
Hi Ljiljana Tubic,
I would be happy to help you with your Officejet 4315. I understand your faxes are printing but there is no ink on the page. I suggest using the following document to troubleshoot the issue:
HP Officejet 4210 4250 and 4300 All in One Printer Series Correcting Print...
If the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 28, 2015 | HP Office Equipment & Supplies
I am looking for a page count to know how many pages have been printed on my HP 5610 all in one printer.
Please follow the steps given below and you will be able to print the system report from the printer.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report. Then select the desired option to print the system report.
Happy Computing
Thanks
Mar 29, 2011 | HP Officejet 5610 All-In-One InkJet...
Prints last page first
The solution for your problem is simple. When you print you have to uncheck the option where it says "Print last page first". Or use the following steps: 1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
If you need further assistance, just leave a comment.
May 23, 2010 | HP Officejet 6310 All-In-One InkJet...
HP J4580 - prints 1/2 page, then a 3-4 min delay before it prints the rest of the page. No error messages, etc., just the long delay. Any advise?
Your printer comes with 16 Mb of non-expandable memory. It could be that you're trying to print a picture that is too complex or too big to fit in the printer memory. If this is the case, it's normal for the printer to print the 1st half of the picture, empty the memory, work on the 2nd half, and then print it.
Does it do the same when you try to print just one page of black and white text WITHOUT any pics? please, do the following test and report back so that I can help you further:
1) Open the wordpad (not Word and not notepad)
2) Copy the following and tne hit "print":
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Mar 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printer will not print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab71
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer reads out "Print Cartridge problem (Tri Color) Refer to device documentation to trouble shoot" I purchased this HP Officejet J4550 All-in-one unit new and haven't made any color pictures with it....
I discovered on mine, exact same problem, I opened the tray, removed the cartridge, and forced it back in hard and fast. It didn't work the first 12 times but after that, it got a solid connection and it worked. Works fine now. Anyway that's the problem and the problem isn't the cartridge (genuine hp cart here). The problem is on the printer side, the pins that hit the cartridge. Anyway get rough with it, slam it in and out, close the tray, if it doesn't work within 5 seconds, open the tray and do it again. It WILL work.
Mar 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer is printing twopages per sheet ( HP 6310)
The HP All-In-One printers have a PREFERENCES/PROPERTIES option called "Pages Per Sheet" that controls this behavior. If it was changed by someone, you can set the default by right-clicking on the printer from the PRINTERS window and selecting PROPERTIES. Then click on PRINTING PROPERTIES from the GENERAL tab and set "Pages Per Sheet" to 1.
If this helps, I would appreciate the feedback.
Thanks!
Dec 02, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
409 people viewed this question
jasbo
jasbo
