Question about Kenmore 23022 Top Load Washer
Found bearing while changing belt
We found a bearing while changing the belt on our Kenmore HD Washing Machine. Can't find where it goes. Can you please tell me the possible place for it.
  • 60 Answers
I think what you are talking about is a spacer it goes under one of the 9/16 botls there should be three of these and if you look you should see a gap where the spacer should be let me know how you make out
Posted on Sep 14, 2007
SOURCE:
Serial number on washing machine does not match what can I do
Usually serial numbers are found on doors which can sometimes be swapped out and replaced by similar make from another machine.chances are you just need the model and make as belts are quite universal within the makers model range.
Nov 27, 2014 | Kenmore Washing Machines
I have a wf320 washing machine and the drum is not turning freely .I have removed the top and found the belt had come off but when i try and turn the drum it gets stuck and it sounds like something is...
It could be that the bearings that have gone. This is not an easy fix but you can try by searching this site (fixya) for solutions regarding change of bearings for your brand of machines. Not impossible. The next problem which is possible is that the spider arm is broken. This arm is inside the drum and cannot be seen unless you open up the drum, most likely it is the arm. For the bearings it could be a grinding noise, but the tub will turn if turned by hand. I am giving you suggestions, not solutions. While searching this site type out your make and model number of the machine. While dismantling note which part goes where for re-fitting.
Mar 31, 2013 | Washing Machines
Once it goes to the last spin cycle ,( the fastest one) it starts making a thumping sound . could it be a belt or bearing?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore front loading spin noise small vibration
It is probably the bearings on the rear of the wash tub. There have been multiple issues with the bearings. Try rplacing the bearings and the drive belt. I also have a 417 that I've had for almost 10 years.. I've not have a problem yet but it is slightly louder on spinning than it was when it was new. I did some research and found out about the bearings.
Dec 15, 2009 | Kenmore Washing Machines
My Kenmore washing machine Model #11082984120 will
it IS driven by belts you need to either replace the belts youself or call in a serviceman.
Aug 01, 2009 | Washing Machines
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
Kenmore top-loading washer won't spin
take cabinet off, from the front, control panel first, then lay on back and take water pump off then motor off and you will see where the couple goes on. Pretty simple job how ever you may be missing some transmission clutch plates that will make it grab and stop with a bang like that.
Dec 21, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing machine belt won't move
You probably have bad spin tube bearings. Look above transmission for a water leak or evidence of one.
May 27, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore 23022 Top Load Washer Logo
Sal De
fordexpert
yobo007
yobo007
