I'm attempting to install a d-link wbr-2310 wireless router on my laptop. The install wizard stops me early when checking the network connections and tells me "No wired adapter connect (i.e. Ethernet Port). Obviously, I connect through my modem and an ethernet cable to get online so that jack works fine. What do i do?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    you may wish to check your wiring diagram..sounds like something is amiss..
  • 6,674 Answers
Believe it or not, I had similar problems and actually called the help # on the card with the router. 5 min. & I saved a ton of aggravation, that I never would have figured out.
Posted on Oct 19, 2008
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
Jun 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Configure d-link wbr 2310 and now wont connect
Hi mech_warrior,
Press the reset button of the d-link router for 30 seconds, unplug and plug the power cord.
MAC cloning is used for Cable ISP configuration but that should not affect the router's functionality (odd router behavior) ;-)
That should do it!
Angel
Jul 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 wireless stops resonding randomly.
unplug for 10 seconds, plug back in. These units to tend to get a stat build up charge
Nov 08, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have a Gateway nv52 laptop and a dlink wbr 2310 wireless router. I can not connect to my network, but I can connect to my friends syslink. If I plug right in to the main motorola router, I get...
So that means you are able to connect to the network with the ethernet cable only.
Did yopu try to connect to the wireless network ?
And if yes then what was the error message ?
Click Here for more info about wireless connection. Pl. go through the web site you will get the answer !
Oct 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I can't access manually my wbr-2310 (modem router dsl-500b)
you need to configure the wireless on the router through a cable connection at first. after logging in on the router (default admin login and password should be mentioned in the router's manual) you can enable the wireless and the DHCP. to access the router, open an internet browser window and surf to the address http://192.168.0.1, where you will be asked to fill in the admin password.
please keep us posted on any evolution
Jun 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Installation problem of D-link wbr- 2310 wireless router
plug everything in first and just run the router, that's what i did and then set up the disk later
you dont really need it personally
Feb 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless Acer Aspire 6930 Does'nt Connect to WBR 2310
  1. Firstly make sure that you are connected using the cable.
  2. open internet explorer type 192.168.1.1, hit enter
  3. on the page that comes up put in user name as admin and password also as admin
  4. click on wireless settings in the left navigation menu
  5. make sure there is a check next to Enable Wireless
  6. setup a Wireless Network Name this can be anything you like
  7. leave the rest as defaults
  8. come down to Security Mode change this to enable wireless security WEP basic.
  9. set WEP key 1 to any ten digit number, make sure you write it down.
  10. click on save settings on the top
this is one part of the solution, in the next part we'll configure your computer
  1. click on start
  2. click on control panel
  3. click on network and sharing center
  4. click on setup a connection
  5. follow the wizard and when it prompts select you're wireless network and put in the key as the 10 digit number.
  6. after the wizard completes you should be able to go online wireless, unplug the cable and give it a whirl.
if you still have issues, please post back.
please rate the solution if your issue gets resolved, it makes it worth the effort.
Feb 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
