posted by stara on Jun 13, 2006
I have a Kenmore Elite model 20992992. The automatic dispensor for the bleach and fabric softener isnt emptying. Water is spraying on the back of the inside of tub area during the drain cycle. It doesnt want to drain and spin in the wash mode but I can manually turn the selector to rinse/spin and make it drain and rinse.
I havent removed anything yet...It sounds like a hose has burst, but could it be something w/ the timer/selector?
Best Solution
posted on Jun 13, 2006
Stara, sounds like you have a couple of issues going on here. On the model you posted there was a service flash on the dispensor. They redesigned it to provide an additional air gap for release. There was also a flash on the bleach hose splitting and leaking. The service flash numbers are 26-747 for the despensor and 26-746 for the hose leak. It almost sounds like your transmission is not going into it's nuetral drain. After completeing the agitation, it should drain for about 90 seconds before spinning. This would be a gearcase problem. The gearcase is covered for a period of 5 years, part only. You might want to check where you bought this unit and see if the parts are covered under warranty. Including the dispensor and hose. You would have to pay the labor..Hope this info helps
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Kenmore 24032 \ 24036 Top Load Washer
Email this problem
Email this problem
This Problem Also Relates To:
Kenmore Elite 45986 Front Load Washer
Kenmore 98702 Stacked Washer / Dryer
Kenmore 2.1 cu. ft. Compact Portable Top Load Washer
Kenmore 44072 Front Load Washer
Kenmore 4292x Front Load Washer
Kenmore 15944 / 15942 Top Load Washer
Kenmore 22622 Top Load Washer
Can you Help with these Washing Machines problems?
what does F1 error mean
what does F1 error meam on... Answer This...
kenmore oasis washer
I keep getting H C when my... Answer This...
Oasis Elite top load washer F1...
I am getting an F1 code every... Answer This...
Older kenmore washer...
Did they really design this gem... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
