Question about Baumatic Dishwashers
Baumatic dishwasher is not rinsing properly - Baumatic Dishwashers
  • Baumatic Master
  • 19,396 Answers
If your dishwasher does not rinse properly, or is cleaning poorly, it is because of the following reasons, check these links:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Posted on Oct 18, 2008
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
What is the setting for 1to 4 inside dishwasher for domestic use
This is for the amount of rinse aid that gets dispensed. The harder your water, the higher the setting should be. If you use a water softener, adjust the number downward. Start low and make sure that dishes are drying properly, if they are not, increase the number slowly until everything dries properly. That way, you never use more of the rinse aid than you need.
Jan 05, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
No manual for baumatic dishwasher bd 45.1
dishes are left with detergant on them, not ricing properly
May 19, 2010 | Baumatic 18 in. BDW45.1 Built-in...
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
BAUMATIC BFD47SS dishwasher won't start
Sounds like the water inlet solenoid valve is not opening. Not easy to get at to test, but if water is available at the hose inlet connection as you say there isn't anything else stopping water entering the wash cabinet.
Shouldn't be a lengthy repair - so I'd recommend getting a quote.
Aug 09, 2008 | Baumatic Dishwashers
Baumatic Dishwasher
http://www.espares.co.uk/parts/dishwashers/baumatic/bdw15/p/1083/1533/0/511574
Jul 15, 2008 | Baumatic 23 in. BDW5 Built-in Dishwasher
Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Nov 22, 2007 | Dishwashers
Does this when it can't drain properly - check there's no debris in the collecting basket.
Jun 28, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Dishwashers Logo
312 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
