Question about Remington 16" Electric Chain Saw
Remington ld4016 w
The chain came off while cutting a tree limb. I cannot get it back on. What steps should I follow? Thank you.
  • chainsaw01 Oct 18, 2008
    yes i need help
  • baldwins Mar 28, 2009
    need to replace the chain on remington LD4016AW
There are one or two large nuts on the chain side. There is also a screw adjustment on the front where the bar or chain guide meets the saw. You loosen the nuts a bit (so that you can move the bar). Then you back the screw out to allow the bar to move back into the saw enough for you to put the chain back on the bar in the guide slot. Then you tighten that screw to the point that you can still push the chain around the bar (wear gloves) and there is very little slack under neath. Then you tighten the nuts. As you tighten them, pull up on the "nose" of the bar.
Make sure you keep oil in the reservoir and oil a lot as you cut. Keep the chain adjusted, they stretch as you use them. RTFM
Posted on Oct 19, 2008
Saw works but stops when I begin cutting a limb. Model # 104316-04 Thank you in advance. Joe Alcamo
Hi, make sure the chain is not on too tight, It should lift from the bar about a quarter inch. Also if there is a chain brake make sure that it is disengaged. If the chain stops but the saw is revving high then there may be a worn out clutch that needs to be replaced. Finally make sure the limb that you are cutting is not binding the chain under its' own weight.
Nov 16, 2010 | Remington Electric Pole Saw
What's the best way to use my 16 in electric saw to cut off tree limbs?
This is somewhat subjective. Eveybody does it a little different.If you are cutting limbs from a tree, start an undercut about where you want the limb to fall free of the tree. Use the upper edge of the chain to cut it about a fourth of the way through. Then start from the top of the limb over where you made the undercut.
Sep 25, 2010 | Remington 16" Electric Chain Saw
Tighten chainsaw chain - model 100089-06 remington 14" limb & trim - how to
There is a very in depth explanation in this Remington OM.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Remington Electric Chain Saw
Plastic cog stripped remington
You provided no model number; you need it to find parts on the breakdown here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If it returns NLA try a part number search here, sometimes they still have the part.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Are you aware RemingtonPower is no longer in production? Often eBay is the only source. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH Lou
Apr 09, 2010 | Remington Garden
After cutting down a tree, my chain stopped or became jammed and now the chain is loosely hanging. How do I adjust the chain to get it back to working order?
Remove the cover on the chain side of the saw and loosen the bar and slide it out to take out the chain slack. leave a little slack to allow for free movement.
Good luck and be careful.
Mar 22, 2010 | Remington 16" Electric Chain Saw
I was using my Remington 14'' limb N' trim chain saw and the chain slipped off. How do I put it back ??
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Mar 21, 2010 | Remington Electric Chain Saw
Where can I get parts for my remington limb n trim chain saw model # lnt-2, serial #037215
Your model is LNT-2 you can find an IPL here:
http://www.desaparts.com/remington-chainsaw.html
I recommend you print it. Click the part number you need. HTH
Lou
Sep 26, 2009 | Remington Electric Chain Saw
When i use the electric saw and put a load on the chain it stops
The problem you have isnt adequately explained.
  1. You may be tripping a thermal overload.
  2. The chain may be to agressive and overpower the motor.
  3. The chain may be excessively tight, that combined with the load may be the cause.
  4. Limbs as the cut progresses, pinch the bar and chain.
  5. No bar oil or defective oiler.
  6. If equipped with a clutch it may be slipping.
There are other causal factors too. Read your manual, limbs require 2 cuts, the first from the bottom about ½ way through, then offset a couple of inches toward the trunk from the top . HTH
Lou
Sep 24, 2009 | Remington Polesaw Wizard
I just bought a replacement chain saw blade for my Remington 14'' Limb & Trim. It is an Oregon brand blade which says it is for 14'' Remington among others. But it is a bit too long for what I have. My...
Take it back to where you purchased it or contact them by email/phone and explain your problem (have saw in hand). Together you can solve this. We cannot find the model number on your saw from here. GL
Lou
Sep 14, 2009 | Remington Garden
Remington 16" Electric Chain Saw Logo
191 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
