Question about RCA P52937 52" Rear Projection Television
RCA 52 INCH D52W20B WON'T COME ON
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power supply kick on and back off. There was nothing wrong with the picture or sound before it went out. Before it went completely out you could press the power button and it would do the same thing. Wait about 30 minutes and it would come on. Now it does nothing. I would like to fix it myself since I have good soildering expertise. I think it's the main flyback on the main board loction is back left of board. I already almost have the mainboard pulled just can't figure out how to remove one wire that is on the flyback. I got the big red wire off, but there is another smaller black wire conntected to it. But just wanted a second say to make sure it's the flyback. Or what else it could be. Thanks Mine is a 52 in rca P52937SG it worked fine when it was new but one day come home from work tryed to turn it on got nothing no sound or video but you can here a small ticking or chirping in the front so I unpluged it the sound slowly went away some one said that it might be a bad flyback? if so where would I buy a new one and where is the flyback at in my tv.
thanks
  • 1 more comment
  • maxmillon1 Nov 01, 2008
    MY 45 INCH RCA IS DOING THE SAME THING GOOD PICTURE GOOD SOUND SOMETIMES I WOULD HAVE TWO HIT THE ON BUTTON ONCE OR TWICE ONE TIME IT TOOK US AN HALF HOUR HITTING BUTTON TO GET IT TO TURN ON.WE WAS GOING TO JUST LEAVE IT ON ARE DAUGHTER SHUT IT OFF BY ACCIDENT NOW IT WONT COME BACK ON AT ALL BLINKS GREEN LIGHT 3 TIMES THEN YOU CAN'T TRY AGINE FOR 1TO 2 MINUTES MAKES SOUND LIKE IT IS TRYING TO START LIKE IT USE TO BUT NOTHING .
  • Anonymous Jan 13, 2009
    has anyone fixed there tv yet. if so how did you do it?
  • Anonymous Apr 08, 2009
    i tried to turn it on, after 5 or 6 tries, the green light went on, but then off again, finially after numerous tries it went on. i'm scared to turn it off again! this happened 3 times now. 2 years ago i had to replace a flyback transformer, it was sparking out the side, that cost 250.00! my model # is d52w19byx1. its a rca moniter 52" hdtv. how can i fix it? judi
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Posted on Oct 30, 2008
2 Suggested Answers
SOURCE: RCA 52 INCH D52W20B WON'T COME ON
I have the same problem. is it worth it to fix it. I got the exact same model and paid 250$ for the tv itself on clearance from rentacenter. what is wrong with the tv?
Posted on Oct 12, 2008
Broken front plexiglass rca 52 inch tv
Hello
Contact the nearest authorised service center for RCA at your town.
Mar 06, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model d52w20b the green light comes on flashes 3 times but the tv wont come on the green power light is supoose to stay on
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
Jan 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on RCA45 inch tv model D52W20B
The flyback is going out and the CP150 capacitor is almost certainly failing as well. You can get the replacement Flyback number 259296 and the CP150 Capacitor at the following link and they provide step by step instructions with pictures so you can easially do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Just fixed it!!! Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
Dec 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937 52" Rear Projection Television Logo
587 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
