Question about Sony Playstation 3 (PS3) Console
System won't power up just beeps three times and nada
60Gig unit that is turned off after a ffew hours use to cool before using agin.
    New Friend:
  • 17 Answers
Have you used can air to blow out the dust ports?
Posted on Jan 27, 2012
SOURCE:
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
Laptop computer will not power up. using power cord and keeps beeping three times every time when powering up.cleaned ram contacts and reseated these. still no change!
Suggest Anti-Static Procedures need to be followed, laptop opened up, and cooling system cleaned.
Also suggest replacing Thermal Paste on Processor, and Thermal Pad on graphics chipset. (Piece of small copper sheet would be better)
What is the Dell's model name and model number?
Bottom of laptop.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Dell Studio Computers & Internet
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 06, 2018 | Kenmore 73055 Air Conditioner
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Hello, I have a Whirlpool dehumidifier Model# AD25USV (recall adjustment already complete) I have never had any technical problems or damages to the unit, and it has worked great, until...
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
Jul 07, 2011 | Whirlpool Dehumidifiers
My hdmi cable wont read signal to my tv.power is on playstation,tv is working fine.help
You may have a corrupt system file. With the system off, press and hold the power button on the front of the unit until it beeps three times. Take your finger off the power button and press and hold it again until it beeps two times and then three times in rapid succession. Connect your PS3 controller to the unit via a USB cable and select option two on the menu that will come up.
If this doesn't solve the problem, call Sony at 800-345-SONY for more help and they will walk you through more steps.
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
My ps3 keeps havin problems where can i get a new hard disk for my ps3 ?
You're assuming the problem is with the hard drive and it's probably not. The hard drive is merely a storage device on a PS3. The system OS is on the firmware of the hardware itself.
Jun 17, 2011 | Video Game Consoles & Games
Ps3 shuts down
It's a over heating issue. Make sure it isn't on carpet, in a closed cabinet, or any other enclosed area, also make sure it isn't next to a heating vent. Let it cool down for a few hours, and it should be ok.
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
