Question about Kenmore 24 in. 15689 Built-in Dishwasher
Not Draining I pulled the filter cover off and found some glass and plastic in the filter area,cleaned it out and it still will not drain.I don't know if this plays into the problem or not,but I replaced the old garbage disposer with a new one.The first time I used the dishwasher after installing the garbage disposer is when I started having the draining problem.
  • Kenmore Master
  • 19,396 Answers
If it does not drain, the drain line can be internally obstructed, follow the instuctions on following link : The water doesn't drain from the machine
Posted on Oct 18, 2008
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Error code e:01
The only thing I can say on this is, Leave it up to the pro's
Mar 12, 2014 | Dishwashers
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
Our Hotpoint WMA20 Washing machine is not draining, even though it appears to do a fast spin. The machine was installed several years ago and has previously worked normally. Is there likely to be a...
Filter is tbe found by removing lower rear cover of washer, and removing the large black hose fastened to bottom of drum, remove and clean plastic filter inside the hose.
Aug 24, 2010 | Hotpoint First Edition WMA20 Front Load...
Dishwasher will not drain. water stays on the bottom of the unit/
Not knowing what make or model you have I can only give you general advice. As a Maintenance Supervisor for an Apartment complex, I run into this all of the time.You will need to start by cleaning out the filter basket. it is under the plastic grate at the bottom of your dishwasher inside of the unit. There are a couple of things you will need to remove, but it is usually just a matter of a few screws. I find food, broken glass, (Be Careful), plastic wrappers and on and on. With this clogged or any impeded water flow the water will not drain. The other area to check is the airgap located on top of your sink. Pop the top off and carefully remove the plastic insert and see it that is clogged. Unless your pump is broken which is doubtful, these are the only two areas that will keep your dishwasher from draining.
May 28, 2010 | Dishwashers
Bosch washer wont drain wvf 2401
You need to locate and clean the pump filter, usually found at the bottom right front of washer, sometimes behind a removeable plastic cover at the bottom.
Please rate my solution.
Thanks.
Nov 20, 2009 | Bosch Washing Machines
Washer won't drain. I washed a comforter and some of the ''stuffing'' came out and now seems to have clogged the washer because it won't drain anymore. I have cleaned out the hose, seems like some of the...
depends on what type of washer it is but it should have a filter on the front bottom of it ,some times they have a plastic cover over them just remove the cover at the bottom of the washer and then turn the filter and pull it out and clean.
hope this helps you
Jul 07, 2009 | GE WVSR1060A Top Load Washer
Viking dish washer won't drain
Try clearing the air gap (which is the seemingly pointless thing that is near your kitchen faucet.)
1.Take off the shiny metal cover, and you can sometimes twist off the plastic cap, or you may need to use needle nose pliers to push in the tabs that hold it in. You may or may not see debris in the tube that is in the air-gap.
2. Now what you need to do is take a clear glass and put it over the air-gap with part of the glass hanging over the edge of the sink, you may want to put a towel around the other side of the glass to keep the water from going all over the counter, turn the dishwasher off then on again and select "rinse and hold". If there is any thing in the line it will come out.
3.If not you may need to take out the filter in the bottom of the dishwasher and on the left hand side in the sump area there is a small, (usually yellow) cap that covers the drain motor impeller that can usually be pulled towards the center/right by hand, if not with needle nose pliers. You will need to vacuum out the water with a wet/dry vacuum or towels.
If none of this works, let me know and I will go over some more uncommon draining problems.
Dec 07, 2008 | Viking 24 in. Professional Series VUD141...
Standing water after cleaning dishes
Clean out the air gap. Remove decorative cover by pulling up. Remove plastic dome by gripping and moving side to side while pulling it up. When you get the dome off you can see if the air gap is partially blocked.
Sep 26, 2008 | GE 24 in. GSD4060JSS Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
67 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
