Question about FrancisFrancis! X3 Espresso Machine
FrancisFrancisX3 - no power
Out of nowhere, I'm getting no electrical current to the machine - we plugged in and pushed the buttons as usual, and are getting no reaction at all. Did we blow a fuse somehow? Is this fixable? Thanks.
  • macsdiving Nov 09, 2008
    Yup, I have the same problem! HELP. She got really hot then stopped working. Please make her better! Any help would be great. Oh, I tried changing the fuse......
  • 3 Answers
There are 3 thermostats in the unit- one for the water temperature, one for the steam temperature, and one fuse which blows if the unit overheats. The overtemp fuse is a 'fuseable link' that burns out if the boiler gets too hot (maybe 150C). If that fuse is blown, then you probably have other problems, since the unit won't get that hot unless the steam thermostat fails.
Even if the thermostats have failed, you should get the power light when the unit is plugged in, and the pump should work, but the boiler won't heat up. If you get no power at all, then you have a wiring fault somewhere.
Posted on May 09, 2009
I need to know where the power switch to my vintage sewmor sewing machine is
It depends on the model of your sewing machine. Usually, there is a push button switch somewhere on the machine. However, some machines did not have an on/off button--just activated as soon as they were plugged in to the electrical outlet.
Mar 11, 2017 | Sewing Machines
I have a Fisher Paykel clothes Washer Model WL42T26KW1. It has quit agitating. It spins, and rinses, but does not agitate. None of the lights are blinking and it is not giving any warning beeps. Can y
Push power button and start button together, push water level up than push start button, turn machine off at wall and unplug it, plug back in and start machine as usual, that may fix the problem, if not, suspect the ECU board is faulty
Nov 22, 2014 | Fisher Washing Machines
Why my Honeywell air purified HHT-149 have no power
unplug and wait for 5 seconds, plug it back in again and hold the power button for 3 seconds.
Aug 07, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
I am now looking for a way to reset the control panel. I understand there is 2 buttons that needs to be pushed and I am wondering which buttons and if the dryer needs to be plugged in to preform this. ...
    • 1Press and hold "Drain & Spin" for three seconds to release the child lock, if the keypad is locked.
    • 2 Press "Pause/Cancel" twice to cancel the current operation.
    • 3 Turn off and unplug the washing machine.
    • 4 Wait several minutes before restoring power to properly reset the machine.
    • 5 Select a new wash setting and push "Start" to begin.
    • 6 Contact Kenmore as necessary if the problem with the washing machine persists. Contact information can be found in the owner manual for your appliance.
Jun 08, 2014 | Kenmore Elite HE4 Electric Dryer
I have checked the plug fuses but there is still no power to the machine
Check the power from your wall outlet. Less than 112VAC, it will not power on. If good, check continuity from individual plug terminals to their corresponding wires. (should be disconnected from appliance first to avoid false readings), if bad, replace cable.If good, check voltage at positive side of incoming terminals at back of connection point and then individual fuse positives, then negatives. (while current is applied) , if good, could indicate a short in the circuit board, or a board fuse, or heater fuse on the motor, or bad display panel. In which case it no longer becomes DIY.
Jun 03, 2014 | Miele W864 Front Load Washer
Error message appearing "power failure occurred
Push the Start/Stop button on the Neptune to reset the machine.
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My kenmore elite he3t washer and dryer are not getting any power. The electrical outlet they were plugged into blew. I have plugged them into another outlet and they do not come on. Is there an internal...
yes there inside of the machineunplug machine from wall take cover off follow power cord goinging into washer should be a button to push in there
Dec 05, 2010 | Washing Machines
Have no weld or power output from a miller starfire 2e, will give very small spark on electrode, but nowhere near enough to do anything, any ideas? brushes are new, cleaned slip rings, checked diodes on...
did you check the breakers im talking about the ones on the unit either switch or push button you can only reset them so many times what happens is there like a set of points in an old chevy they start to get pitited bigger the pits the less power you get less amps are produced just because the reset dosent mean they are giving 100 % you can bypass one and see what happens to that drill you should be happy with the out come zaper fla
Apr 24, 2010 | Hammering
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
Power button
This also helped me. Thanks
Oct 26, 2007 | Whirlpool LHW0050PQ Front Load Washer
FrancisFrancis! X3 Espresso Machine Logo
197 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
