Question about Hoover U5018-900 Bagged Upright Vacuum
No Power HOOVER U5018-900 bagged upright Vacuum
I was vacuumung with no troubles. suddenly vacuum quit. i noticed upon investigating the bag was full and there was some white tissue like material being forced out of the black ring on the back of the unit? doesn't run no power ever since? any help greatly appreciated as i've only had for about 8 months.
Thanks Matt
    New Friend:
    Problem Solver:
  • 6 Answers
Empty the bag, check the belt, and make sure the hose is not stopped up. Just as a heads up, powdered carpet cleaners are ***** on vacuum cleaners. Hope this helps
Posted on Nov 09, 2017
  • Hoover Master
  • 10,459 Answers
Check the opening behind the floor brush for obstructions there.
nwj2468
  • 76 Answers
SOURCE: Hoover 6446 900 WindTunnel Bagged Upright has
check for a clog in the brush hose
Posted on Aug 22, 2009
Samyfam
  • 379 Answers
SOURCE: Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Posted on Sep 16, 2009
  • 231 Answers
SOURCE: Hoover c1810 bagged upright - power keeps cutting
there might be a reset button on there but its not meant for continuous use. we need to figure out the problem why the power cuts out. what condition is the cord in? cuts nicks. also check the prongs on the plug. if not that could be a bad switch but it sounds like a loose connection
Posted on Jan 03, 2010
WonderTech
  • 268 Answers
SOURCE: I need instructions on how to change bag in a
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Posted on Feb 03, 2010
VacuumRepair
  • 438 Answers
SOURCE: hoover self propelled bagged windtunnel upright
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change;
Thank you very much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Hoover has no power. Is there a reset button?
Important Notice Regarding Hoover WindTunnel Series REWIND Bagless Upright... I found some interesting reading here that could pertain to you. Thank you and leave feedback for I am new at this. James please have a great day!
Jul 14, 2016 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
I need a new bag for the Hoover 3.8 Model # U5465-900 which bag is it ?
Hoover Genuine Hoover Type Y Allergen Filtration Vacuum Bags, Fits Hoover Windtunnel and Hoover Tempo Bags Hoover 4010100Y
Feb 17, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Need correct number on a bag. It says Z bag but it doen't fit
According to Hoover, Your vacuum takes a Hoover Z bag. Make sure you dont have a Eureka Z bag, they are different. Let me know if it works.
Apr 12, 2010 | Vacuums
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
HOOVER 6430-900
Hoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
(function(){ var e9 =new expo9_ad(); e9.size ="160x600,120x600"; e9.showAd(); })(); _qoptions = { tags:"ADSDAQ.LAWPOLITICS,501500," }; _qacct="p-01-0VIaSjnOLg";setTimeout("quantserve()",3000);
January 16, 2007
Hoover
hoover.jpgHoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
Whirlpool Spins Off Hoover
Hoover Recalls Self-Propelled Vacuum Cleaners
Consumer Complaints
Hoover Company Inc. has agreed to pay a $750,000 civil penalty to settle allegations that it failed to report to the U.S. Consumer Product Safety Commission (CPSC) the sale of vacuum cleaners with defective on-off switches that can overheat and cause the vacuum cleaner to catch fire.
In April 2005, Hoover conducted a recall of 636,000 Hoover Self-Propelled Upright Vacuum Cleaners because of defective on-off switches.
In June 2004, after CPSC received notice of several vacuum cleaner incidents, the Commission staff requested Hoover provide a full report of incident information. In July 2004, when Hoover submitted a full report, it had notice of 260 consumer incidents, of which 141 involved reports of fire. Additionally, there was one report of a minor burn injury.
Hoover first learned of a vacuum cleaner switch on one of these units overheating and melting in April 1999.
Federal law requires firms to report to CPSC immediately (within 24 hours) after obtaining information reasonably supporting the conclusion that a product contains a defect which could create a substantial risk of injury to the public, presents an unreasonable risk of serious injury or death, or violates a federal safety standard.
These Hoover Self-Propelled Upright Vacuum Cleaners are plastic, upright vacuums with the brand name �Hoover� and words "Self Propelled" printed on the front of the product.
Only those Hoover Self-Propelled Upright Vacuum Cleaners manufactured between May 1998 and November 1999 are included in the recall that is the subject of this penalty.
Jun 11, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5018-900 Bagged Upright Vacuum Logo
71 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
