Question about Toshiba 57H82 57" Rear Projection Television
2 screens what is needed to work the double scrren 2 watch 2 shows at once whit satellite tv
  • 934 Answers
You're talking about picture-in-picture. Simply hook up a second source or split the one cable input you have now into two leads with a splitter from somewhere like Radio Shack. Then bring up the PIP and select the input. Now you have two different things to watch each from their own channel. This wont work if you have dish... But you could watch the DVD perhaps if you hook it into one of the available inputs in the back of the Tv and select that input in PIP mode.
Good Luck!
Bill
Posted on Nov 02, 2008
All other input works fine e.g. dvd, TV went pink screen.
If other inputs show no problems and you are not using a cable box or satellite receiver, etc. just off air antenna, something on the main board is failing. please double check other inputs again.
Feb 17, 2014 | LG 32LC7D Television
Has a black block in the middle of the screen when watching satelite. Is okay when watching DVD, or using the action screen
You may have activated one of the closed captioning modes. Double check the TV and may be the menu in the satellite has a caption mode. But I'm sure the Tv will be the problem!
Apr 08, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
I have problem whit Toshiba 5005-S504.My Windows Xp was **** and i try to reinstall but the notebook can't boot from enythink. I try whit standart way by DWD rom but dwd can't read the disk whit...
Hi, you will have to change the boot sequenc.when you turn on watch the screen and you will see very quickly to press F2 or a different key to go into the bios. I think it is on the first screen to change the sequence - Boot from cdrom then hard drive.
Then insert your dvd and install, if you need more help, please ask.
Jan 30, 2010 | Toshiba Satellite 5005-S504 Notebook
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
We have a black screen with no audio. We are able to pull up the guide, but we can't watch tv or anything recorded on the DVR. How do we fix it?
No fatal error, try this. If you would, please unplug the receiver from the power outlet for about 2 minutes. After 2 minutes, plug it back in and let me know when it comes on (it will do this by itself). Once it does, it should be showing Message 015, “Acquiring Satellite Signal”.
http://tech.dishnetwork.com/departmental_content/TechPortal/index.shtml
Oct 10, 2009 | DISH Network 322 DTV Receiver
Screen goes dark
Either the backlight lamp or the invertor for it is failing. I suspect the colors and contrast isn't as it once was either.
Dec 15, 2008 | Toshiba Satellite M115-S1061 Notebook
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Hitachi shows double image and then no picture or sound.
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 07, 2007 | Hitachi 57TWX20B 57" Rear Projection...
Screen Issue when HD Satellite Receiver is set to 1080i
these tv's are absolute garbage. Ours does the same thing with hi def.
never again for a samsung
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
My tv screen goes green and then turns off by itself
mine does that to but when i turn it on its blue and in like 5sec. turns off by its self
Nov 09, 2006 | Premier Mounts Universal Flat Panel Wall...
Toshiba 57H82 57" Rear Projection Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
