Question about Maytag Neptune MAH5500B Front Load Washer
The door will not open.
The cycle is complete but the door won't open. I tried the start then stop but the front panel is asking for the door to be opened before it will start again.
  • dmoneal Oct 20, 2008
    Same here. It sounds like a solenoid is clicking, but the door is still locked.
  • 62 Answers
This is usally a door lock problem, or control board(you can pull bottom panel off and reach up by door lock and pull on a little plastic ring to release the door, make sure there is no water that can pour out)
Posted on Oct 20, 2008
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Flickering display panel Boschwfe 2021
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
Jan 05, 2009 | Bosch WFE 2021 Front Load All-in-One...
Jennair dishwasher timer stops halfway thru wash cycle.
Try using a cycle that doesn't boost the heat. Usually a quick or china/delicate cycle. Any cycle that heats the water pauses the timer until it is done. Some machines even select this with heated dry. The sensor that controls this can go bad and stop the timer completely. If it operates for the complete cycle , look for the sensor and replace it. There is usually a wiring diagram somewhere in the machine sometimes in an envelope inside the door, control panel or behind the front bottom panel
Jul 04, 2008 | Dishwashers
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Nov 30, 2007 | Dishwashers
Maytag Neptune MAH5500B Front Load Washer Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
