Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Taking top off
Can't get top off to change the tub.
    President:
  • Whirlpool Master
  • 2,651 Answers
There are 2 clips that need to be"popped" approx, 6 inches in from each side along the front of the mchine and the top will lift up.. they are there but are VERY HARD TO "POP",
Posted on Oct 19, 2008
I have pocket change in the bottom of my maytag Bravo washing machine. when the discharge pump runs it makes alot of noise and i have already ruined one pump. I can't see how to get the rest of the...
do a Google search on your model number and type in on how to take it apart. I bet you your change somehow got in between the two tubs. The inner tub and the outer tub.
May 07, 2011 | Maytag Bravos MTW6600T Top Load Washer
SOUNDS LIKE LOOSE CHANGE UNDER DRUM.CAN DRUM BE REMOVED TO GET CHANGE OUT.
Yes, First pop the lid up with a flathead screwdriver. You'll see two clips between the body and the lid panel. Once you get the lid up take the tub cover off. It just snaps on to the tub. There is a plasctic cap on the top of the adgitator that covres ther adgitator bolt. Remove it and remove the bolt, and take off the adgitator. This will expose the 6 bolts that hold the basket on. Remove them and the basket will come off, and you can get to anything in the tub.
Jan 30, 2011 | Maytag Bravos MTW6600T Top Load Washer
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Trying to get top of cabrio washer to pull tub I have coins between drum and tub. How do you get top disconnected
There are two retention clips along the front located about 4-5 inches from each corner. After you get the top up, you will have to pop off the little cover that will reveal the agitator bolt. After removing the bolt, you can pull the agitator and the entire drum (take off top water flow thing as well). I pulled about $1.96 out of the bottom of mine but also had to pull the drain pump to get change out of it as well. For the person that said his washer made a noise during the spin cycle and thought it was a bearing, I would look for change behind the drum and in the pump first.
Thanks,
Bobby
Nov 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sounds like change grinding in spin cycle
This machine is prone to getting stuff down into drain pump. Pull unit away from wall, disconnect plug, hoses etc... Pull back steel panel of of rear of machine, facing rear of machine, drain pump on lower left, rinse pump on lower right, take needle nose pliers or spring pliers and remove hose to tub and drain pipe hose, tilt machine forward, take 5/16 nut driver and remove three screws holding pump, drop pump down, replace pump. Install in reverse order. Then, remove center nut in center of tub, pull center spinner out, then lift top to machine, remove inner tub and clean out metal, money or other stuff from bottom of outer tub, reinstall in reverse order.Once money has gotten into pump it can damage it, so replace it even though it looks good.
Oct 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dc error code just moved
Hello apalo14,
Do you think your FAV6800AW got jarred around in the move?
The FAV6800A/9800A Service Manual on Page 53 will take you thru the leveling process. I would check the front and rear struts to make sure they are supporting the tub correctly. You will have to raise the top of the washer page 33 of the SM will show you how to release the top of the washer. Page 41 will take you through front panel removal of two 5/16” screws. I would remove the front panel and check that tub is being supported by the front and rear struts properly see pages 40 thru 43. With the front cover removed check the mounting of the Tub Displacement Sensor page 42. If those checks all look good I would run the Tub Displacement Sensor check below, this test is detailed in the SM.
3.0 Tub Displacement Sensor Diagnostics check.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you receive these results your Tub Displacement sensor should be OK.
If your machine does pass the Tub Displacement Sensor check and all of the above checks out then as unlikely as it may seem you may have a clutch issue. But let’s see what we have after the above checks are completed.
Apr 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub bearing kenmore front loader
you have to change the whole outer tub that is the only way you can get but take off your top by taking the screws out of the back and then it slides back then see if the noise is coming from the back center of the tub if so if will need to be changed and the tub is expensive
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
My washer leaks occasionally from the back
ok i need a lilttle help from you,,,ok,,,open lid..take your hand and put it on the top of the agitator,,push the hole agitator and tub back,,and let it go if the tub stays back and does not come back center by its self,,your counter balance spring broke,,no mattter which way you push that agitator it shoud come back to near center..what could be bad counter balance springs ,,or tub surport springs.if you need help removing and changing please post
Dec 03, 2008 | Kenmore 15864/15862 Top Load Washer
Changing front loader seal
easy.isolate from mains. take top off.remove clamp that holds seal to cabinet and unpeal seal from cabinet. seal is held to tub by a clamp (like a huge jubilee clip) undo and peel seal from tub. when fixing new seal, lubricate with washing=up fluid
Dec 11, 2006 | Hotpoint WMA58 Front Load Washer
the way i done it was open the door take take the wire band of around rubber seal__as in picture one.__2 take top of machine of and take spring of as shone in picture 2 you shold be abble to take silver band of around rubber seal
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
