Question about Philips 42PF9630A 42 in. Plasma Television
No picture but sound
I have had this TV for a week and the Cable guy came to put in Digital Cable today. Within an hour I was plugging in video cables for my DVD player and putting the Tv against the wall and the screen went black and said Channel can't be found. I went to the menu and changed it to DV1 and now I have sound and can change the channels via my box but I still have a black screen. What's up with that?
  • Josh Cooper Jun 13, 2006
    Ok I have the five cables (two of which are audio) that are all connected going from the Cable box to the back of the TV. There are two reds, a green, a blue and a white I have now disconnected all DVD cables and I am concerned about getting the main picture back. Still having the same black picture with sound. the weird thing is that I can get the menu up fine on the screen but no TV picture
  • Anonymous Dec 09, 2008
    NO PICTURE ONLY SOUND
    President:
  • 3,130 Answers
How did the cable person hook up the cable? Was it thru an rf connector and you need to put the tv on A channel . Or are there video and audio cables from the cable box to the tv? We need to have more info please. Thanks
Posted on Jun 13, 2006
  • Larry  Dillon
    Larry Dillon Jun 13, 2006
    ok your using the rgb input cables and the tvs not switched to the proper input is what it sounds like. Something got switched off or not on the right mode.
Power cord is shorting out
The cable guy may have bumped the power connector and loosened it. Try pushing it in firmly. Sometimes the power connections get loose over time
Oct 03, 2012 | Toshiba Televison & Video
Viera TH-46PZ85U. gray box where picture should be
If it was a setting on the television, then the cable info would also be affected. Try a reset on your cable box, as the cable info is generated within the box from the data stream, whereas the picture is streamed from the provider.
If the reset doesn't work, it's time to call the cable company - it's not a fault with your telly.
Mar 05, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
you might try checking the sap (secondary audio programming) option in your tv if it has one make sure it is turned off. if it is off or does not have that option you will most likely have to take it to a repair shop. i would not try to fix it my self as you will do more harm than good.
Dec 09, 2008 | Insignia IS 20" TV040919 TV
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Yamaha RX-V363 input settings
HI,you are not getting picture because the yam 363 dose not upscale or convert the picture from the composite input to hdmi.You will have to put a video cable from the composite out put on the amp to a scart convertor into the tv or put console picture into the tv and sound to the amp.
hope this helps.
CABLE GUY.
Jul 17, 2008 | Yamaha RXV-350 Receiver
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
HDMI SOUND PROBLEMS
yes u guys nee dto do all the hdmi directto tv then optcal digital back to sterio digital in for sound only ect not throw sterio kills picture also
Jan 30, 2008 | Yamaha RX-V661 Receiver
Philips 42PF9630A 42 in. Plasma Television Logo
249 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
