Question about Sony KP-61XBR48 61" Rear Projection Television
Popping; sparking of Red Projector to metal frame
Bought this Sony Projection new, but started to crack and pop a few weeks ago. Removed the back and found the Red Projector Unit is arching to the mounting rails from the projector power cable; could this be a bad windings? If so is there a fix or does the entire Project need to be replaced? How much and where can I order one.
Thanks,
  • coe288 Oct 19, 2008
    Thanks MisterSony, but is there more to your response? What can I do? Do I need to replace the entire CRT? Any ideas for cost of new CRT.
    Thanks,
  • 320 Answers
Sounds like the red CRT has an internal short. Sometimes happens that the picture tubes develop an internal short and cause arcing. I world CAREFULLY disconnect all of the wires to the CRT and see if the arcing goes away. VERY IMPORTANT!!! there is a high voltage wire attached to each pictur tube, usually a red wire that goes to the side of the tube. You can get a shock even if the TV is unplugged, as the tube will hold a charge for years after the power is disconnected. If you don't feel comfortable doing this, DON"T since the shock is powerful enough to stop your heart.
Posted on Oct 18, 2008
  • Any Guy
    Any Guy Oct 19, 2008
    Yes you need to replace the RED CRT but there is more to consider. The arcing may have damaged additional componenst, so there is that cost to consider. A CRT (if available, and some no longer are) will likely run between $150-$200. Second, the CRT which does most of the work generating the brightness is the Green CRT, so if the picture is dim you may be looking at replacing another one (or two) CRT's in the near future. Bottom Line: In my opinion, investing in repairs for this set is risky, but the choice is yours
Popping sound on my toshiba 32" flat screen
pls. cheked
1. suond ic input supplay voltage (ic B+ voltage regestance 1 ohm.
and capacetar 2200um/35v replace)
Oct 04, 2009 | Zenith R57W46 57" Rear Projection...
Loud popping noise and spark coming from red projector
I would guess you have a High Voltage Leak at the Anode Lead Cap where it Mounts to the CRT. This is not a area to mess with You are better off calling a professional to fix it. It may be a little difficult to confirm if it is a intermittent problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony grand wega kf-50we610 red lamp light blinking
The red light means that the prjection bulb needs to be replaced. They ony last about two years depending on hours of use. The low popping sounds as well as fan noise is normal for the Sony projection TV. You can Google the owners manual by entering the brand,model etc. and ask for the owner's manual. I had to go to several sites but eventually found it.
Jun 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Popping, snapping sound
Hello fulby2001,
Have the CRTs checked for grid to cathode shorts. The CRTs do this (pop and crack) when they have Grid Cathode shorts. I would advise having a qualified TV technician do this for you.
Thank you,
I hop this helps
Shuttle83
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 61H70 Popped Loud & Fixed Then Popped Again & Again ;(
my guess is that that high voltage seals on tubes are leaking out high voltage from tubes if not probly sealed with silicon they will leak out high voltage.replace them and seal coorrectly this may fix your problem
Jan 17, 2008 | Toshiba 61H70 61" Rear Projection...
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Flashing color in and out with popping sound
This sounds like the solder joints have cracked on the AFT can inside the tuner, a common Sony problem. Removing the tuner, opening it up and resoldering the grounds and small transformers inside should clear it up.
Jun 26, 2007 | Sony KP-43HT20 43" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
