Question about Toshiba 2060 Copier
C 41 hi i have a problem in toshiba cope all the time no work and c 41
  • Toshiba Expert
  • 414 Answers
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Thanks
Best Regards
Posted on Aug 30, 2012
A 2060 toshiba photocopier have a problem of not printing, wat is the solution
Posted on May 06, 2012
Try replacing the thermal fuse in the fuser. Then reset your C41 by using the "08" mode, code 89, reset to 0. If that doesn't work, replace the thermistor and do the same procedure again.
Posted on Oct 02, 2006
  • 163 Answers
.press and hold 08 while turning on the copier reset your C41 by using the "08" mode, code 89, press start key change the figure coming on the display to 0 then press interrupt key then off and on the machine,If that doesn't work, replace the thermistor and do the samTry replacing the thermal fuse in the fusere procedure again
Posted on Sep 14, 2007
SOURCE:
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
What does code 41 or error 41 mean as my dvd/cd burner in my toshiba laptop is not working and is showing this error message?
Follow the procedure below to remove the error message :
This procedure works for XP OS :
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right panel, click UpperFilters.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Exit Registry Editor.
Restart the computer.
If your OS is other than XP let me know .
Hope this helps.
Thanks for using Fixya.
Mar 14, 2010 | Computers & Internet
41 device error
i have a problem 41 device error in the toshiba dp80f
Feb 17, 2010 | Toshiba DP80F Printer
Error 41
Error 41 -The head drive voltage has not been turned from Low to High within the specified time.
Check:
• Carriage ASSY
• Main PCB
• Print head unit
• Power supply PCB
Hope i helped you.
Thanks for using 'Fixya'.
Jun 23, 2009 | Office Equipment & Supplies
Frequent interrruptions
Initially, I would suspect the battery (even when plug to the AC). To confirm, pls try running without the battery and purely on AC adapter. Alternately, it could be a loose component internally such as the memory, LAN or WiFi card and in some models, video card. In my Toshiba, it turned out that the WiFi was consuming too much power that it discharges the battery rapidly and the charger was having a hard time coping up. My solution was to turnoff the built-in WiFi and install a D-Link USB.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Computers & Internet
Replace toshiba satellite m40x (z008) 60GB toshiba HD with a Samsung HM160JC 160GB HD
both HDs must be either sata or ide and each one must not have a password lock.
good luck
Dec 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
415 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
