Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
Starter rope trouble
With a TB320bv. The starter rope will not pull.
The on/off stop control is on. Throttle control is at 1. The gas tank is completely full, and the fuel cap is securely on. The primer bulb has been pushed ten times.
  • Anonymous Apr 13, 2009
    I have the same issue with one of their Spring assist line trimmers. One of the problems could be that the piston is "stuck" at top dead center. They say to remove the spark plug then pull the starter rope to free it.
  • 163 Answers
It might be vapor lock, try taking the spark plug out and giving it a pull
Posted on Nov 30, 2008
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do you start it/
    Check:
    - Gas in gas tank
    - Oil level correct.
    - Tiller drive in off/disengaged position.
    Start procedure:
    - Fuel selector - ON
    - Ignition switch - On
    - Choke - On
    - Throttle position - Slow
    - SAFETY - No children within 10 feet/
    Pull Starter rope......
    Repeat 3 - 5 times only.
    If engine starts, release choke as required until engine runs smoothly.
    If no start,
    - set Choke to OFF, Throttle to FULL,
    - pull starter rope 3 - 5 times only.
    - if start, reduce throttle to obtain smooth idle
    - if No start, start check for:
    - Spark at plug
    - Fuel in the jug
    May 22, 2015 | Garden
    How to replace the pull string on my Cub Cadet ST2020 weed eater.
    Very fun job Not. Very involved and time consuming.
    First your should be about 3 long some unit uses slight longer ropes and it is probably a number 3-1/2 rope.
    1. Need you to separate the upper drive assembly from the engine assembly. You may to disconnect the throttle cable and the ignition kill wiring.
    2. Remove the clutch cover.
    3. Disconnect and remove the spark plug.
    4. Install a piston stop in place of the spark plug.
    5. Remove the clutch drum. Has small screw in center; usually has a Trox head on it.
    6. Remove the clutch assembly. Usually has left handed threads so turn it clockwise.
    7. Once the clutch is removed then you need remove the starter cover assembly and the air cleaner cover assembly.
    8. Once the starter cover assembly is off remove the pull rope pulley and check for damage.
    9. Depending the pulley design you can now install a new rope first or you need to re install the pulley.
    10. Tighten the pulley fully by turning the direction as you would pull it until it stops and back off one turn.
    11. If the pull rope hasn't already been install install it now. Otherwise make you have the pull handle on the rope and release the pulley tension slowly until the rope is tight.
    12. Now re-assemble everything in reverse order.
    Feb 12, 2015 | Garden
    How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
    Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
    • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
    • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
    • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
    • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
    • Once you are satisfied that the recoil is working properly re-install the remaining covers.
    Jan 15, 2015 | Toro Garden
    PULL ROPE IS STUCK ON A TROY BILT BLOWER
    Partial disassembly of the machine will be required to access/diagnose the exact problem. The starter/recoil unit goes on top of the flywheel and the flywheel is on the engine shaft. The obstacles will be removing the main cover (and getting it back on correctly). If you have never done this, them maybe take pictures as you disassemble it to help you reassemble. Once you reach the starter/recoil unit, you will see how it works and be able to resolve the problem. Some of these units have inferior design and engineering flaws where they mate nylon parts with metal and of course, the nylon doesn't hold up. Post back for more help if needed once you get to the starter unit.
    Feb 10, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
    Need to replace starter cord on Tecumseh LV195EA engine for walk behind lawn mower
    This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
    1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
    2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
    3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
    4. Remove what is left of the old rope.
    5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
    6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
    7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
    8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
    9.Reinstall everything in reverse order.
    Nov 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
    I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
    Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
    Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
    Using a spark plug wrench, remove the spark plug.
    Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
    Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
    This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
    Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
    Pulled choke and power swith is on, keep trying to pull the cord and stll won't start,yes it has gas
    hi , try this, take the spark plug out. and leave it out for awhile ,to dry out.1 hour,clean plug ,put it back in the machine.then take the air cleaner off, make sure it is clean for later,get acan of aerostart or starter fluid NOW SWITCH ON, CHOKE OFF THROTTLE IN START POSITION''''' FULL THROTTLE ,AQUICK SQUIRT OF AEROSTART INTO THE TOP F THE CARBY AND PULLTHE START ROPE 3 OR4 TIMES NO MORE ,THE ENGINE SHOULD FIRE OR START;;;; if it does not at least fire you may have to try anew spark plug,if it fires but does not start, pu ll the choke out 1/2 way and pull 1 or 2 times only or you may flood it again,giv it another squirt in the carby and try again but dont keep pulling the starter as you will get crankey when ite rope breaks .if it starts let it run for afew minutes stop it replace the air cleaner 1/2 choke pull the starter should go push choke rightin after a couple of pulls start it and go to work.Please if this doesn`t work come back and tell me what happened for we may have to make a couple of adjustments
    Aug 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
    Craftsman weedwacker 358.791070 suddenly stopped
    could have been caused by any number of thing's,
    take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
    rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
    Jul 31, 2009 | Garden
    Starter rope will not retract.
    inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
    Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
    357 people viewed this question
    Top Troy Garden Experts
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Wade Mobley
    Wade Mobley
    Are you a Troy Garden Expert? Answer questions, earn points and help others
