Question about Maytag Neptune MDE5500AY Electric Dryer
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat.
  • esheire Dec 18, 2008
    Coin operated dryer does not blow hot air. Works fine otherwise but doesnt dry clothes. This is a Maytag coin operated machine and is gas. Can ya help me out???
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Posted on Sep 13, 2009
    Scholar:
  • 112 Answers
I would start by checking the continuity of your thermal fuses on the unit. You will have at least one and they will be located around the heater element or ducting near the heater element. If they check out good, check to see if you have an open element.
Posted on Oct 18, 2008
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
futureloginn
  • 734 Answers
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Dec 28, 2009 | Washing Machines
Dryer works but is only blowing cold air. just bought the dryer last year and have already had it repaired once.
my Samsung was in a flood(so solution may only apply to floods), changed heater assembly, still blowing cold air, turned out to be the little black box on the generator, took box cover off,cleaned the connectors in box and voila...instant heat
Nov 28, 2009 | Samsung DV448AEE Electric Dryer
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
The tumble dryer is work but is only blowing cold air
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Maytag Neptune MDE5500AY Electric Dryer Logo
1,706 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
