Computers & Internet Logo
JOe Posted on Jan 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you send and recieve faxes through Majic Jack ...Would you use the cable modem or computer modem to set up...
Marvin
Level 3:
Top Expert:
  • Telebit Master 85,242 Answers
  • Posted on Jan 27, 2012
Marvin
Telebit Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29048440
Points
266281
Contact Magic Jack product support for this, we do not have any info on this problem here at Fixya.
1helpful
6 months ago I had my Majic Jack plugged into my Century Link Modem. Now i do it again and my Majic jack won't work. Why?
The reason why your Magic Jack isn't working now could be that Century Link has updated their modem, and the new modem is incompatible with the Magic Jack. Another possibility is that the Magic Jack itself is no longer working.
If I were to troubleshoot this problem, I would first try plugging the Magic Jack into a different modem to see if that works. If the Magic Jack still doesn't work, then I would contact customer support for Magic Jack to see if they can help me troubleshoot the problem.
I hope this helps.
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
1helpful
Fax thru Internet help
Magic Jack is lying to you. ALL fax machines are Analog devices, Magic Jack is Digital
4helpful
Does magicjack allow the hp officjet 7410 to send and recieve faxes
You should be able to send and receive faxes with the majic jack.
I have high speed through my cable co. when i try to fax it says it can't find the modem
Correct. Your printer does not have the capability to send a FAX.
Is there a telephone-cable between your printer and the telephone-jack in the wall of your home?
Also, your computer has no add-in FAX modem, or your computer does have a FAX modem that does not have the correct device-drivers installed.
Intellifax 4100e no modem, cant get dial tone cant send or reciev
We need to start from the wall jack
check with another phone to see if good
on the side of your fax there are 3 jack inlets EXT., PHONE & LINE
you need to go from the wall jack strite to the Line jack nothing els in front of the fax like a modem. ansering machine Est.
If this does not work dubble check jack phone line. phone cord
If not then you have a bad phone board est. cost $150.00 Installed
hope it works for you
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Hp oficejet 5610 all in one not recieving
bad modem board. plug a phone into the ext jack see if you get a dial tone. The modem board can be bad even if it can send but not recieve.
I can't receive and send fax
The splitter the technician is referring to goes on the wall jack. One should have come with the "modem" installation package.
Take a regular telephone cord and plug one end into the splitter and the other into the line jack on the Fax/printer.
When your done you should have two phone cords connected to the splitter - one going to the "modem" and the other to the printer.
Top Telebit Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Telebit Computer and Internet Expert? Answer questions, earn points and help others
