Question about Toshiba CZ36V51 36" TV
Remote signals The remote control will not operate the TV. Have changed the batteries, tried a universal remote and ordered a new replacement from Toshiba of this model and none will operate the TV.
    President:
  • 3,130 Answers
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
Posted on Jun 12, 2006
Correct code for universal remote will not turn off tv. On the 50" digital led model ELEFT502. Original remote always had a weak signal worked only when pointed a foot away from infared reciever. Then quit...
No universal remote control will work with any TVs as well as the original ones. If the original remote control do not get range, there are two reasons for it; and can be repaired to.
1. Battery weak [Replace with new batteries]
2. The infra-red light emitting diode at the front of the remote control is weak.[Can be replaced with a new one. It can be bought from most of the electronic spare part selling shops]
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 06, 2015 | GE Televison & Video
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Universal remote not transmitting
Universal Remotes are so inexpensive that you are better off getting a new one than to try and spend the time to fix the remote. But here is some things to consider.... Did it STOP working when the batteries went dead? Have you put in the NEW CODES (normally on the Back of the Remote) to communicate with your equipment? Have you set up the Remote yet? You can not SEE Infared, how do you know it is not sending out a Signal?
Start by removing the Batteries and replacing them with new ones (unless you can measure the output of the Batteries with a Multi-meter). They should be close to 1.4 volts. Because a light comes on does not mean it is strong enough to operate the TV or other equipment.
Mar 01, 2014 | Universal Remote Control Televison & Video
I have a UMC TV /DVD Combi the remote control i got with it no longer turns the TV on or off, so i bought a universal remote and it cant seem to find the code for the remote so i was wondering would anyone...
First of all, did you put new batteries in the remote control?
That usually solves the problem, because when the batteries get weak
the output infrared signal also gets weak.
With a new universal remote control, there is a booklet containing the
codes to use for many different TV receivers. If your specific TV model
is not listed, try using one that appears to be similar to it. If that does
not work, try turning your TV on with the new universal remote. If you
can turn it on, then you may be able to have the universal remote
program itself by interacting with your TV. Turn it on and hold the
remote so that it points to the TV set and hold it there for about 30
seconds. Then try turning the TV off and on again and try to use
the channel change feature. Try this a few times to give the TV and
the remote a chance to talk to each other. Keep the remote pointed
toward the TV.
Aug 29, 2011 | Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Try this:
  1. TV off
  4. Turn on TV
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
I JUST PUT BATTERIES IN THE REMOTE AND IT WILL NOT RECIEVE THE ORDER FROM THE RMOTE WHAT SHOULD I DO THE T.V. BRAND IS ESA
To troubleshoot the remote control problem, follow this step. 1. Check the battery (new if possible) 2. Get a ordinary radio then scan the radio to no signal frequency...just a buzz song will be okay. 3. Try to point your remote control in front of your radio, then press any keys (numbers or anything) 4. If you heard some sound to the radio while pressing the keys 4.a Your remote control is working fine. 5. If you did not heard anything while pressing the keys 5.a Your remote control is not working. You need to replace it or just buy a universal remote control (cheapest way to do).
Thanks. Hope this helps.
Mar 09, 2011 | Televison & Video
When I try to change the channel, the "TV" button blinks, yet the channel doesn't change.. What do I do?
This is usually due to low batteries, The remote is sending a signal and the TV is receiving it, but the flash pattern from the remote isn't being recognised by the TV. Try replacing the batteries and post back.
Regards,
BElectric
Nov 14, 2010 | Universal Remote Control Remote Control
My tv stopped responding to the remote for some odd reason ( the remote seems fine ) how do i reset it ??
the problem is the IR Receiver in the tv needs
replacing,this is the receiver thay receives the
signal from the remote.there is no reset for
this type of problem.Also you my try new batteries in the remote and a new remote if the
IR Receiver does not repair the problem.
Sep 04, 2009 | RCA Universal Remote Control
42-inch Protron LCD TV Remote Doesn't Work nor Does a Universal Remote Replacement
Your problem is not with the remote but rather the circuitry designed to respond to the signals transmitted by the remote(s)
Find out what board has the circuitry that responds to the remote signals and replace that board. Got a better idea?.
If very expensive then you have 2 choices - deal with a remote less set or get a new one.
Mar 22, 2017 | Protron PLTV-32 Television
I need a remote control
well this is a tv remote, and you cannot use a universal remote for this. maybe the tv has buttons marked"tv/video" dat youll have to press manually if not then try to get manufactr replaced remote dat came with tv
Jan 08, 2008 | Televison & Video
Toshiba CZ36V51 36" TV Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
