Question about Toshiba Computers & Internet
Toshiba Tecra A7 won't start on docking station
My Tecra A7 that won't start when it is on the docking station (Toshiba Advanced Port Replicator III Plus). It hangs at the screen that says "Windows is Starting...". It starts fine when it is not docked. If I put it on the docking station once it has been started it works fine. I recently formated the HD to try to solve the problem. I blew canned air into the connections on the station and bottom of the computer. None of the pins on the computer or station appear to be bent or damaged in any way. Can you suggest any solutions? Thanks
Andy
XP prof, 2GHz, 1G RAM, McAfee
carsandcomps
  • 722 Answers
SOURCE: my toshiba tecra m10 won't boot when on the docking station
Hello scottgrumish - when you have the computer off the docking station, start it up, and hit F2 or F11, whichever it says to enter Setup. Enter password if any. Once in setup, you'll see a File Menu. For each Menu, push F9 (or, at bottom of screen, look for command list, and locate the command key for setting Default Settings. Starting with the first Tab on the File Menu, hit the F9 key (or the Default key indicated at the bottom) move to the next tab in the file menu...do this for each, until you reach the last. The last tab (Exit) will give you the options: Exit Without Saving Changes, Save and Exit. You want to Save and Exit. The system will then reboot from the beginning, and open windows. Run Disc Defragment which can be found from the Start Menu, All Programs, Accessories, System Tools, Disc Defragment. When the Defragmenter Program open, it will prompt you for which Drive(s) to Defragment. Choose Drive C:\ (Hard Drive). Analyze the drive first to ensure whether it needs degragmented or not. This is just to check. Upon completion of the Analysis, regardless of the result, click the Defragment button. This may take several minutes to a couple of hours, but it is a necessary maintenance operation that should (is recommended) be completed regulary. (Scheduled Degragmentations are best). Once the defragment is complete, again restart the computer. It may seem a bit minotonous, but restarting refreshing the system. Make sure the Trash bin is empty, after the computer has reboot agian. If you know of any programs that are installed, that are not necessary for the computer, you, or any other programs to run or operate, uninstall any of these as they are merely taking space and use up CPU usage; yes even if they're closed and not being used, they take up memory and space. Consider this a type of "Spring Cleaning". If you have an anti-virus program run it as well. To uninstall the programs (if any), go to Start Menu, All Programs, Accessories, System Tools, Disc Cleanup and use this to get rid of such programs (unused). Also, go to the Start Menu, and on the right hand side (or whereever it's located on your computer) go to Control Panel and locate 'un-install a program) Look through the list and un-install any un-necessary programs that you see in the list that you know are not needed or used. If your are not sure, leave it. NOTE: Anything that says Microsoft, Windows, (or anything that contains your computer name or brand, do not un-install). Never, uninstall any file or program with the extensions .dll, .exe, or .bat (agian, if you're not sure, leave it).
Once you have completed this (if there were any), again, restart the computer to refresh the system (it may suggest this automatically).
Now, shut down the computer, dock it, then try to open windows again. If it still does not load up windows (or your OS (operating system), I suggest contacting the dealer or manufacturer (or where you got it) and asking about they docking system and operation of the computer and it's compatibility and options.
I sincerely hope this information is helpful and helps you solve this matter. Let me know if I can further assist you. Thank you for choosing fixya.com.
carsandcomps,
Guru
fixya.com
Posted on Apr 04, 2009
SOURCE: External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Posted on Jun 29, 2009
  • 64 Answers
SOURCE: toshiba pa3064u-1pcc macintosh
You have to turn on sharing on both computers first, assuming the Toshiba allows it. Your Mac does. Then you can connect it using ethernet or USB. Unless they are both connected to a network, sharing is the only way to go or if it will even work.
Posted on Sep 10, 2009
SOURCE: wireless access
my wireless card was working great, then stopped all of a sudden. If I connect to the Modem directly it works, do I need a new wireless card?
Posted on Feb 07, 2010
  • 10406 Answers
SOURCE: two toshiba laptops, one less than a year old
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Posted on Feb 21, 2011
Toshiba undock
Hello Eleanor,
By your question I can not tell if you have used the docking station or not so here is the removal procedure for a Hi Speed Port Replicator II
To disconnect the Port Replicator, follow the steps below.
1. Set the computer lock to the unlock position.
2. Make sure you perform
one of the following:
• Save all your work.
• Turn off the computer's power in any mode: boot, suspend or hibernation.
• Perform any software disconnect operation required by the operating
system.
• Press the eject switch.
CAUTION:
Make sure the Eject LED is out. Do not try to disconnect the
computer while the Eject LED is glowing.
3. Pull the eject lever out towards you to disconnect the computer.
4. Lift off the computer
Now if there are further problems or this did not help you please post further information like at what step did the station not perform correctly. Hope this helped.
Nov 29, 2013 | Computers & Internet
Windows 7 driver
You can download drivers from the manufacturer's website. Have you tried windows update?
Feb 23, 2013 | Dell PR01X D/Port Docking Station & Port...
No audio from docking station PA3314U-1PRP. Laptop itself (Tecra M5) outputs audio normally. All other outputs from the docking station work normally. How do I get audio to work through the docking...
you should try plugging from the output port of the laptop to the input port of the docking station, remember the source is coming from your laptop going to the docking station.
Now for the microphone once you have the settings right the line in jack should work properly.
Hope this helps!
Jul 22, 2011 | Toshiba Advanced Port Replicator III...
Can I use a high speed port replicator on my Toshiba A665-S6086?
You can use the new version of the replicator. The USB version. You will have the same features as an ordinary docking station.
Jan 20, 2011 | Toshiba Satellite A665-S6085 Laptop
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
Aug 22, 2009 | Toshiba Dynadock Port Replicator, Docking...
Dual monitors: DVI and VGA not supported simultaneously
It looks like this a problem for the Port replicator III, not II, right? I'm not an expert on port replicators, but if you have even an ok video card, it should work fine even running all three...
Feb 03, 2009 | Toshiba Advanced Port Replicator III...
DebitGuy
Thanks in advance
Stu
Jan 08, 2009 | Toshiba Advanced Port Replicator III...
Drivers for docking station?
The driver that's needed for docking station (it's more a port replicator than a docking station) support is Toshiba's Mobile Extension 3. After that, it oughta support warm/cold dock/undock.
Go here to find and download Mobile Extension 3: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=160273&rpn=PS610U&modelFilter=6100&selCategory=3&selFamily=1073768667
Jun 19, 2008 | Toshiba Satellite Pro 6100 Notebook
Computers & Internet Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
