Question about HP LaserJet 4730mfp All-In-One Printer
4730mfp Have 2 problems says is out of magenta but not and says copy/send error
    Problem Solver:
  • 8 Answers
Re: copy/send error....if it is not a scanner issue, do you have a problem with starting up/initializing error.... if so, it may be the hard disk failure - consider replacing it with a 40 or 80gb sata drive - may need to do nothing more complicated than replace the diskdrive which is mounted on the formatter card, which is retrievable out the back. The card is the metal faced plate on which the network/usb plug is mounted.
Posted on Nov 07, 2008
How solve error 49 on 4730mfp
it's a long one !
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
1.hp desighnjet 500 showing an exclamation marn on magenta printhead 2. error 59.99 on hp colour laserjet 3700
The exclamation mark means that the magenta printhead is already low in ink or have encounter a problem. Try removing and reinstalling the magenta printhead, if that didn't work, you will need to get a replacement for your magenta printhead since it could be low in ink.
Sep 21, 2011 | Office Equipment & Supplies
LaserJet 4730mfp - does not print anything at all - scans to email fine, goes through the motions of printing but paper comes out completely white. does not copy either. all cartridges are fine no jams and...
Is this printer new? If so make sure the little plastic tabs are pulled off of the ink cartridges Located at the bottom covering the jets. This will stop the printing. Hope this helps Merry Christmas and happy new year.
Dec 23, 2010 | HP LaserJet 4730mfp All-In-One Printer
Sir, i am using Konica Minolta C252. I am getting error message C-2553. If i opened the front door and closed then the error message will go, but again it will come after some copies. What is the problem...
Magenta Image unit mite be the problem have it replaced if it already was then mite have a bad new one also check the sensor that monitors the toner for the magenta Also pull out the magenta image unit shake side to side to spread out the develop inside the image unit along the entire length of the image unit reseat the image unit.
Aug 20, 2010 | Konica Office Equipment & Supplies
No poweraftereplaced the adf scanner in hp color laserjet 4730mfp
Make sure you reconnected all of the cables when you replaced the scanner. Unplug and reseat the connectors -- maybe one of them is not seated all the way in.
May 27, 2010 | HP LaserJet 4730mfp All-In-One Printer
Printer head magenta/cyan [m/c]
copy and paste this link in the address bar of your internet explorer and you will know what to do
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01628836&cc=us&lc=en&dlc=en&product=2512009
if you reach service the product that means somethings wrong with the logic card of the printer and you need to replace the printer
Oct 11, 2009 | HP Officejet Pro L7680 All-In-One Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
No error code
there is a prob in the transfer unit, you need to send this to a shop or call for service
Sep 22, 2008 | Xerox DocuColor 12 Printer
CLC 1120 code e071, sub code 001
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors ther may be toner or paper dust.
May 20, 2008 | Canon CLC 1120 Color Copier
HP LaserJet 4730mfp All-In-One Printer Logo
527 people viewed this question
Seeker5211
Seeker5211
