Cannot find remote code for a Misakai TV model number 1301.
We have a Phillips universal remote and we can not find the correct code to program the remote to our Misakai tv, model number 1301.
Hold code search until the light stays red
then
click TV
then
click CHANNEL UP
then
once your t.v. responds (by the channel going up)
click OK.
Your remote is now programmed.
Posted on Oct 29, 2008
Can't find manual for Phillips Universal remote. Need codes for LG TV
what is the your phillips remote model number? Model number is located under the batteries. then go to www.p4c.philips.com to get the codes...hope this helps
Jan 06, 2012 | Philips Magnavox Learning Universal Remote
I have a g e universal remote and i dont have a code for it to work on a phillips tv
Good day!
This are the 3 digit codes for your Phillips TV. 003, 004, 006, 008, 062, 068, 069, 074, 075, 076, 086, 087, 089, 133,
This are the 4 digit codes for your Phillips TV. 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
How to enter codes manually:
  1. 899 Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
  2. Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
  3. Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
  4. Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
  5. Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
I hope this information will be helpful.Thank you and good luck.
Apr 23, 2011 | Universal Remote Control GE174Universal...
Hi i have A Misakai t.v. model-MTV2002 I'VE tyred all kind's of universal remote's cannot find out no t.v code for a universal remote can u help i'm lost thx-u number's & stuff about this company...
Hi Dennis
Your TV is made by Funai Corp. of China. They make many brands of TV and many are identical inside and just have a different badge/casing.
http://www.funai.us/index.html
You didn't state which brand/model remote you have so I can't offer any specific codes, however, if you try codes for some of the other brands manufactured by Funai - see following list - you may get one that works:
Funai
Magnavox
Symphonic
Sylvania
Superscan
Element
Philco
Durabrand
Trutech
Emerson
ESA
Personally, I think Funai, Sylvania and Emerson are the most likely. Try these and if you have no luck, post back with your remote model number and I'll see what I can find.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 08, 2010 | Televison & Video
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
I just got a dish installed and cannot program the remote control
What you can try:
- Check the DirecTV code set for the following brands:
Funai, Symphonic, Sylvania, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Your set and the above-named are all built by Funai.
Even if you find one that works, it probably will not give you full functionality as would the original TV remote, which you can probably find at http:\\www.remotes.com
Before you buy any 'universal' remote, please don't expect it to absolutely work with your set; there is no such thing as a 'universal' remote.
If you find one that interests you, take the time to look up the mfr.'s website and check the code lists for your set.
Sep 04, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
I have a Misakai TV, and a RCA Universal, but I can find a code for to program the TV....help...
goto RCA.com click on the support/downloads section, enter the model number of the remote, and you should be able to download a copy of the manual or view it in your browser, to look up and find the right code for your TV, if this helps please give a fixya rating, thanks
Jul 19, 2009 | Televison & Video
I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Philips Magnavox Learning Universal Remote
TV code for Emerson EWC 1301 TV/VCR Combo
how do use revmote to program tv vhs thank you11
Jun 15, 2008 | Emerson EWC1304 13 in. TV/VCR Combo
I need the code to program a magnavox remote to a RCA tv
A magnavox remote should program like the phillips universal. I will post the link. If this doesnt help post the model number of the magnavox remote that you are trying to program. the model number is usually in the battery compartment.
Feb 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
1,412 people viewed this question
Top Televison & Video Experts
Electro Med Services...
