Question about Apple iPhone Smartphone
Iphone doesnt vibrate
My iphone doesnt vibrate it just rings
  • 1 more comment
  • Anonymous Jan 03, 2009
    I have a similar problem
  • aznbebeblu Feb 04, 2009
    Yea, my phone wont vibrate, maybe the vibrate can be replaced? has anyone bought the part on ebay and do the replacement. Itd be nice to show me how (maybe a video somewhere). Thanks.
  • drakentu May 11, 2010
    Did you also check that the vibrate button is switched up on the left hand side above the volume button?
I had the same problem: my phone wouldn't vibrate at all... I read a lot on other forums and found the following solution: If you turn the phone face down, and hit it on the metal side a couple of times (I hit it with just enough force not to cause it any damage) the vibrate will come back on. I almost didn't believe this, until I tried it.
Good luck to you all.
Posted on Mar 20, 2009
    Scholar:
  • 48 Answers
Check and make sure you dont have the feature turned off, also try a factory reset, their new software has a lot of bugs. After you get the reset done do a software update on the phone. If not take it back to apple that is a manufacturer defect.
Posted on Oct 20, 2008
2 Suggested Answers
SOURCE: my Apple Iphone does not
I have the same problem! I have done everything, but still only vibrates.
Posted on Jul 29, 2008
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
I phone 4 it doesnt ring in or ring any alert sounds
Check the left side of the phone, there's a little switch, if you see red under the switch, click it the other way. Problem solved.
Feb 01, 2013 | Apple iPhone 4 I.D.rubberize Hard Case w/...
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I have 3g apple phone i can received calla but so sounds just vibrate
if you mean the phone doesnt make noise when it rings, check the ring/vibrate switch on the left side, and make sure that the volume is turned up all the way when it is set to ring. you can tell when you flip the ring/vibrate switch because onscreen appears either a bell, or a bell with a line through it. if that doesn't do it, you may want to see if your speakerphone works when on a phone call, because i'd say it doesn't and you have a hardware problem that requires contacting apple either at the apple store, or at 1800aplcare
Apr 02, 2011 | Apple iPhone Smartphone
My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
Mar 29, 2010 | Apple iPhone 3G
Iphone doesnt ring
Is the volume up fully (click on the volume buttons on the side)
Is it on vibrate? Very easy to inadvertently knock the sound switch to vibrate, which is located next to the volume buttons.
Hope this helps. Let me know if it doesn't.
BReady
Mar 25, 2010 | Apple iPhone Smartphone
Phone doesnt ring only vibrates
I had the same problem - on the left hand side of the phone (not the screen) if there is a red dot showing you have switched your phone to silent. Click the switch and your phone will ring
Jun 16, 2008 | Apple iPhone Smartphone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
859 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
