Canon imageCLASS D780 All-In-One Laser Printer Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer Is it a color printer?
parkerguy
Level 2:
  • Expert 138 Answers
  • Posted on Oct 19, 2008
parkerguy
Expert
Level 2:
Answers
138
Questions
Helped
132651
Points
295
No. This is Black & White Only. Single Black (L50) Cartridge System.
Fix colors adjustments after factory reset in printer ricoh spc262
To fix color adjustments on a Ricoh SP C262 printer after a factory reset, follow these steps:
Open the printer driver and go to the "Maintenance" tab.
Click on the "Adjust Color" button.
Follow the prompts in the wizard to adjust the color settings for your printer. This may include adjusting the color balance, gamma, and other settings.
Click "Apply" to save your changes.
Print a test page to see if the color adjustments have been successful.
If the color adjustments are still not satisfactory after following these steps, you may need to calibrate the printer. To do this, follow these additional steps:
Click on the "Calibrate" button.
Follow the prompts in the wizard to calibrate the printer. This may include printing a test page and adjusting the settings based on the results.
If you are still having issues with color adjustments on your Ricoh SP C262 printer, you may need to consult the printer manual or contact Ricoh customer support for further assistance.
Print colour pictures from laptop to printer
If your printer can print in color and your printer is set to print in color, then you need to do nothing else, it should print in color. There are only 4 things that could prevent you from printing in color. 1. The printer settings is set to print in shades of grey. 2. The printer itself is set to print in black and white only. 3. There is no more ik in your color cartridges. 4. You don't own a color printer.
My printer is not print same color my design printer r230
Buy Cheap printer ink from Peachtreeink.net They are Good Quality printer inks manufacturer with best quality.
Visit Cheap printer ink website at http://peachtreeink.net
1helpful
Printer A10922 will only print in black. Color cartridge renewed 1 year ago and has been working well.
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
2answers
Printer not printing in color
There is an option in the printer driver to print in color, B+W or greyscale - make sure it is set to color.
2answers
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Color feature is turned off. Need to turn it back on.
Go to Start Menu, Printers and Faxes and right click on the printer, select Printing Preferences, go to color tab, and uncheck print in grayscale
1helpful
Color Printer Inks
No.  The answer I have found it to  hook up another printer also. I use a  B & W pin printer for most of my printing and leave the color printer turned off unless I wantto print a color document. Both are installed at all the times. Windows allows me to specify which printer I wish to use.
1helpful
2answers
Phaser 850
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: [email protected]
2answers
old marine
old marine
ZJ Limited
ZJ Limited
