Question about Toshiba 32A33 32" TV
Picture & sound goes off and on continuously...
Standard Toshiba Tube TV 30"? just started with the picture going blank & no sound and then within a minute, it comes back on. This seems to continue no matter how long we leave it on. Any thoughts? TV is about 7 years old. Thanks
  • 525 Answers
Check for bad connections
Posted on Oct 20, 2008
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba televison picture keeps going yellow
Sounds like the blue is disappearing from your picture. A common cause of this is bad solder connections which can cause the blue signal to be lost at several places. It could also be due to picture tube failure. Sadly, I'm leaning toward tube failure because of your description. Bad solder connections usually take some time to start acting up after you turn on the set, but you say this happens every time within a few seconds. This is typical of a picture tube failure where an internal connection is okay until the tube heats up, and that takes only a short time. A service shop could check the set to make a firm diagnosis, but if the tube is the culprit you should replace the TV. It's not economical to consider tube replacement.
Apr 08, 2009 | Toshiba Televison & Video
Screen goes black every few seconds but have a picture
Sony incorporates a video blanking circuit that blanks the picture out when the picture tube begins to get weak. sorry, but short of replacing the tube, there's no lasting solution to this problem. I used to have some success rejuvenating the crt, but I found that it didn't last but a few hours before the blanking circuit starts to activate again.
Apr 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Nov 20, 2008 | Sony KP-53HS10 TV
20 inch wega @1999 Picture comes in and out
Try to finde lose connection/ cold solder joint at board attached at end of picture tube. It seems heater/ filament voltage not being supplied to picture tube after a while and picture goes to black.
Jul 22, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Picture issues
a short grid with an internal cathode in the CRT
Sep 02, 2006 | Toshiba CF32G50 32" TV
Toshiba 32A33 32" TV Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
