Question about Panasonic Home Theater System System
Panasonic SC-PT760 The wireless speakers are not coming on. The red indicator light is on and won't turn green.
  • 9 Answers
Try pairing process.
It is in the main set Operating Instruction manual.
I cant really remember the whole process clearly but definitely in it.
Posted on Jan 06, 2009
Subwoofer does'nt link with sound bar
  1. The wireless link indicator lights red. Or alternates red and green.
    There is no link between this unit and the active subwoofer.
    Check that this unit is turned on.
    Ensure that the digital transmitter is fully inserted
    into the digital transmitter dock on this unit.
    Turn the active subwoofer off and then back on.
    Alternatively, turn the active subwoofer off, disconnect the AC power supply cord and then reconnect it.
    Consult your dealer if the problem persists.
    Taken from the Panasonic SC-HTB520 Manual
Oct 26, 2012 | Panasonic Audio Players & Recorders
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Chgr error on my panasonic pt760 discs will not eject
Lock123 already solved my problem great service no wait time your site is the best one out
Jan 24, 2010 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SC-PT760 that won't turn on!
if it was stored in a damp area it may take awhile for it to turn on until it dries out.most units have a dew protection sensor on them
Jan 17, 2010 | Panasonic SC-PT770 Theater System with...
My Panasonic SC-PT760 system just doesn't sound right. It sounds perfect with every function besides the AUX. Music and DVD's sound how I think a surround sound system should work but my LG HDTV sounds...
it definetly sounds like their is a set-up issue or a grounding issue , refer to your user manual for reference to check your wires ,also bad buzzing sound also comes from cheap rca cables that you might be using for components to your system ,also sometimes the end jacks of the rca get worn out and don,t provide good conductivity , auxillary inputs should be used for playstations or x boxes and not for anything else , hopefully this was helpful, sincerely Glenn
Mar 02, 2009 | Audio Players & Recorders
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Panasonic SC-PT950 Wireless Speakers Question
It is pairing process again.
Inside the Main set operating instruction can help you solve it.
Aug 13, 2008 | Panasonic Home Theater System System
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
Panasonic Home Theater System System Logo
320 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
