Question about Bulova Watch
Slazenger Digital watch
I have a four button Slazenger ditial watch code 13070 50WR
I can't set the time no matter what buttons I press in any order. can someone please help
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Posted on Dec 23, 2008
SOURCE: how to set time on Harajuku Lovers digital watch
See, you just have to hold the blue button (in TIME 1 "T1") till the screen tell you "LIGTH OFF", then push the green button and u will see all the option.
i found it by myself... i took time but i did it...
i hope this can help u...
see ya....
Posted on Dec 27, 2008
SOURCE: lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Posted on Feb 17, 2009
SOURCE: Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Posted on Aug 23, 2009
taran_2005
  • 10515 Answers
SOURCE: digital umbro watch purchased 2001.How to change
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
Posted on Oct 06, 2009
How do you change the date on a slazenger watch please help me
push the MODE button until the DATE blinks then with the SET button change it . then press mode again
Jan 16, 2016 | Watches
How do I reset the countdown timer on a slazenger digital watch...please
Try Googling (Slazenger)(model)(manual) without parens to get instructions.
May 12, 2017 | Watches
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
I bought a ladies armitron watch.. and can't reset time.. day etc is fine.. the symbols left hand side say 'set' 'mode' right hand side 'ADJ' 'AL' ... can you help.. Thanks Leanne
Thank you for contacting FixYa.
  • Look at your watch as if it were a clock face, even though it may be a digital. Most Armitron watches have four buttons around the perimeter of the watch. There will be a button at the 2 o'clock position; this will be button "A." There will also be a button at the 4 o'clock position. Consider this button "B." On the opposite side will be button "C" at the 8 o'clock position and button "D" at 10 o'clock.
  • Press the "D" button until the numbers begin to flash on your digital watch. Press and hold the "D" button again until the seconds begin to flash by themselves. Press the "B" button to advance the seconds. You may hold down the button in order to cycle through the numbers faster.
  • Hold down the "A" button in order to move on to setting the Armitron minutes. Once they begin flashing, press the "B" button just like you did to adjust the seconds. Press the "A" button one more time, and you will see the hours flash on your watch face. Hold down the "B" button and cycle through, making sure the a.m. and p.m. is correct.
  • Change the date on your Armitron watch by once again pressing the "A" button. This should cause your date to blink. Press the "B" button to change the days.
  • Cycle through the months by pressing the "A" button one final time and holding down the "B" button.
  • Aug 27, 2010 | Armitron Watches
    I need user manual/instructions for Slazenger, model not known
    mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
    Jun 27, 2010 | Watches
    How do I set time etc on a coleman sports watch, have manual but doesn't make sense, it's model 40-408
    The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
    Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
    When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
    Coleman 40-408 User's Guide
    Nov 03, 2009 | Bulova Watch
    Cl 5008 Can't set time. holding down set button gets to an offset option.
    Try resetting your watch first. To do that press all four buttons at the same time.
    Then to set the time, hold down the set button until the display flashes. You can then use the mode button to cycle through the display features and set them. Use the strt/stp and reset to adjust fields.
    Oct 16, 2009 | Columbia All Sport Digital watch
    Slazenger digital watch - can't find instructions
    try this. same principal, buttons may be in different place. worked for me!
    http://www.buydakotawatches.com/PDF_FILES/Digital.pdf
    Jun 04, 2009 | Casio Watches
    Bulova Watch Logo
    588 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
