Question about RCA T19408 19 in. TV/VCR Combo
Tv plays only 60 seconds and shuts off
I turn the tv on it plays for 60 seconds and then shuts down.
    President:
  • 3,130 Answers
You have with this set whats know as a regulator problem. Since there are no user serviceable parts in this set im sorry to say your gonna have to take this set into be serviced unless you under stand television circuits. You will need a service manual and a good multi meter and monitor the output from the regulator IC . If it fluctuates all over the place replace it. If it dosent then its in the regulator driver circuit. Good Luck
Posted on Jun 12, 2006
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My screen is blank except for the arrow. I've rebooted several times but nothing comes back up. The lights at the top, i.e. DVD, play, ff, stop, mute and volume, are on and won't toggle.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion dv7-1130us laptop
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Samsung TXE2546 25" TV Problem
Check for hot spots on circuit board = solder any/all bad connects + check for bad capacitors.......T
Oct 23, 2007 | Samsung TXE2546 25" TV
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
RCA T19408 19 in. TV/VCR Combo Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
