Question about Maytag MES5870A Electric Kitchen Range
Whirlpool 465 large capacity electric ceramic top oven failure
Hi I have a oven failure whirlpool 465 electric ceramic top stove
It is giving me a E1 and F1 failure code lost the manuel can you help me
Thanks
Doloimaz@qwest.net
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Posted on Nov 10, 2009
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool stove Super Capacity 465 problem
Hi dcisco,
Happy to help you!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 23, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag MES5870A Electric Kitchen Range Logo
432 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
