Question about EnGenius EOC-3220 (EOC3220)
Antenna Do I need to configure setting in the router if I want to use an 18dBi antenna? And if so how do I do it?
  • Carl Navarro
    Carl Navarro May 11, 2010
    Every access point I have used with a larger antenna, we just screw 'em in. Keep in mind that the weaker wireless cards might be able to see the bigger antenna, but not transmit back to it. Generally the fringes get a wirelss bridge, which is a wireless router or access point in bridge mode to receive the strong signal and send back to it.
  • 481 Answers
First off, the EOC-3220 series comes in two choices: the ones ending in EXT, which require you to add an external antenna, and the ones without, to which there is no place to add an external antenna. So there is no decision to be made in the software configuration, because it's all handled above the software's pay grade.
Other Engenius models with "either/or" antennas come with a physical switch that allows you to choose between the internal antenna and the external jack. So again, there's no software contribution.
Posted on Oct 28, 2009
Dlink external antenna configuration
Hi .In my Experience if you Change the Antenna Must be equal Both are Antenna Like 12 dbi Otherwise you are facing the Slow Issue.
must be same DBI Antenna (on my Experience 2700 AP I Face same issue ) when i change the Antenna both are Equal It s Fine working Thanks
Feb 04, 2014 | Computers & Internet
Someone just told me to try this website. I am trying to find an answer. We have a 16MB connection in our flat but when we went inside the room we cannot connect. We can connect only if we went to hallway....
You need an app that will display all the wifi in the area, by power and channel. I'd suspect that you are getting interference on the same channel. Try a different channel, move the antennas around, make a directional antenna, reduce the shielding between you and the router.
Apr 06, 2017 | Aztech Computers & Internet
Poor antenna
does this happen to other wireless devices you have as well? If so, there's no problem with the wireless capability of the laptop. what you can do check the wireless broadcast of your router. usually, it is set to max or to 10. you can check it by logging in to your router. you may also want to change the wireless channel of your router. if you can give me the model of your router so i can give you steps on how to configure your router..
regards,
josh
Nov 01, 2011 | Advent Netbook
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I just bought the airport extreme and now my computer internet goes in and out constanly. I have rewired the house, had the telephone repairmen out twice, and had my DSL people on the line countless...
Try a different antenna configuration.
I just read an article in last weeks Micro Mart magazine.
It was very surprising how the signal strength and range can alter depending on the type and angle the antenna are set at. If there are 2 antennas, angle them at 90 degrees to each other in a V shape, also try fixing them horizontal rather than vertical.
Aug 04, 2010 | Apple AirPort Extreme Router
The wireless network will not work
yea dude its depand upon ur router antenna or wireless settings either configure properly or not <not more than it>>>>>>check ur settings to.
May 11, 2010 | Actiontec GT704WG Wireless Router...
Getting ready to replace my 2WIRE router
The solution may be as simple as placement of the router/antenna, or it may be a configuration mismatch between the MacBook and the router. 2Wire is a fairly common router used by some ISPs, the router might be configured to use IPv4 and the Mac might be configured to use IPv6 (different address schema), or the channeling might be set different (encryption setting mismatch). Since the problem seems to occur mostly with the newer computers, I would lean more toward a configuration problem, but recommend checking the antenna first (this would automatically transfer to a new router), then check the settings. Depending on the environment of the router, the time may have come to get a new one (I have seen some last many years and some last only months).
Check that the following are set the same on the router and the Mac's:
  • IP Addressing schema
  • Encryption settings
  • Channel and frequency settings
If you are going to relace your hardware, I recommend a router with MIMO technology using the 802.11g standard. As far as the 802.11n standard, keep in mind that it has not been approved and published in its final form yet, this could mean that any technology using this "pre-standard" may become obsolete and unusable overnight.
Dec 29, 2008 | Monster Cable (109611)
Stronger antenna
unscrew the antenna, and buy an rp-tnc connector and an n-male, then get an antenna with female n-type connector. LMR240 coax is better than RG58 for 2.4. which ever you use get the connectors to suit. Then crimp or solder them to your coax and away you go. no need for other settings ... just ssid of access point.
Oct 18, 2008 | EnGenius EOC-3220 (EOC3220)
CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Jan 18, 2008 | Cnet CWR-854 Router
EnGenius EOC-3220 (EOC3220) Logo
186 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
