Question about Nikon Coolpix 5700 Digital Camera
CAMERA WON'T TAKE ANY PICTURES
MY CAMERA WON'T DISPLAY ANYTHING, IT ONLY SHOWS THE PICTURES THAT HAVE ALREADY BEEN TAKEN ON THE MEMORY CARD. IT WILL ONLY SHOW A BLACK SCREEN WHEN TURNING IT ON !
  • 188 Answers
Your camera has a damaged CCD. the only solution to fix the problem is tochange the CCD.
Posted on Jun 25, 2006
SOURCE:
When i turn on my camera, it won't read my memory card and won't bring up my photos that are already on my memory card. I put my memory card in and i go to take a picture and it says 'pictures...
If the card was one that was previously used in another camera, you can't use it in this camera without formatting it. Move the pictures to a computer and format the card via the camera (remember that all data on the card will be erased). Before formatting the card however, make sure the battery has sufficient charge as this process can take some time. Also remember to never interrupt this process as it can damage the card. The format option can be found in the settings.
Note: pictures taken on one camera can't be viewed on another camera.
Jun 23, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
If display screen on camera is damaged, will the pictures already taken be damaged?
No your pictures already taken are fine as they are stored on the memory card.
If there is no other damage to the camera you can still take pictures and they too will be fine.
Hope this helped. Please rate the answer if it does.
Mar 11, 2010 | Fuji FinePix J10 Digital Camera
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Dec 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have a memory card that hold 700 or so pictures,
It could be, that what you are seeing, is the INTERNAL memory is being taken up with your pictures. Connect your camera to your computer with a USB cable and you will probably find them.
Oct 04, 2009 | HP Photosmart M417 Digital Camera
When you take a picture, camera shows memory card error
These cameras are on the list of the ccd problems.
Here is a link to the site you may need. Canon will repair it for free if it is the ccd problem. Note that they will pay for shipping both ways as well if it is the ccd problem. Call them on the toll free number.
Canon Repair Service Center
Aug 31, 2009 | Canon PowerShot A75 Digital Camera
Camera does not show taken ( saved) pictures
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
Feb 19, 2009 | Nikon Coolpix L15 Digital Camera
Pictures are not taken.
I would try another memory card. Do not buy cheap ones.
Dec 24, 2008 | Nikon D70s Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
I have the same problem since yesterday! When I switched on the camera it shows only black screen with all the settings on it. I can change the settings and I can take a picture,but it will be only a absolutely black picture! :(
Jun 12, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
96 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
