Need remote control code for Studio Series 54" tv
I recently changed my satellite provider & cannot get the DirecTV remote to change volume, mute, turn on & off, etc.on my tv without the code for my original tv remote. It's a 2002 or 2003? model 54" Studio Series tv. I've tried several codes I've found for Orion, Samsung, but no luck. Can you help me find the right code so that I don't have to use 2 remotes?
Thanks, rapple
  • stephmj28 Dec 07, 2008
    i need the code also. my remote became "unprogrammed" if that can even happen. i would love it if u could give me the code.
TamirN
  • 5 Answers
SOURCE: Studio Series 54
http://www.directv.com/learn/pdf/Remote_Controls/universal_remote_user_guide_new.pdf
Find the 5 digit codes for your TV
Switch/Slide your remote control mode to TV mode.
Press Mute and Select button together and hold it until TV mode flashes twice.
Using the number keys, enter 5 digit code for your tv brand.
Press Off button. Try every single code until your tv turns off.
Some common brands and their codes:
If your TV is
- Sony, code is 10000
- Toshiba, code is 12006 (most models and make sure your remote control is version RC64)
- panasonic 10250 most models
- Samsung 10702 most models
- sharp 10093 most models
Posted on Oct 19, 2008
  • 68 Answers
SOURCE: lost my manual for my remote need codes for a quasar tv the remote is a ge 2150 v2
you can buy a universal remote from AV shop and tune to any TV. Can buy one that works as combos for TV, DVD, VHS etc, does away with all remotes
Posted on Sep 21, 2012
  • 3 Answers
SOURCE: I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Posted on Sep 24, 2012
info2ukg
  • 11 Answers
SOURCE: i went sharp tv lc13s4 remote control service code
See the left side of tuner on pcb, you have got a micro switch. push the switch n get service menu.
Posted on Oct 27, 2012
AJIN G
  • 6694 Answers
SOURCE: I'm using oon remote control model number onb13avoo4 I need the code to control a zinwell 950a converter box
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Posted on Jan 06, 2017
I have Direct TV. I need to program, my remote to it. I need the code for model # SK-32H650G?
https://support.directv.com/app/answers/detail/a_id/4028/~/how-to-program-directv-remote-control
full directions:
1. tv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 1, wait two blinks
4. enter 1
5. press and release VOL UP
6. point the remote at the tv and keep pressing and releasing the CH UP key, if and when the volume changes
7. press select to lock in code
Jul 04, 2015 | Westinghouse Televison & Video
Need to know how to put tv code in a direct tv remote
on your directv remote move the switch on the top to right until on tv. then hold select and mute on remote until it flashes twice. then enter 981. that will clear any memory on remote. then hold select and mute again until it flashes twice. enter 9911and use the channel/page up button and press it up once at a time until tv shuts off. after tv shuts off press select. then hold select and mute again until flashes and enter 960 and that will let it control inputs. then move switch back to left on directv logo and enjoy.
Mar 25, 2012 | RCA DIRECTV Satellite Remote Control
I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
Manufacturer/brand of Studio Series M5400 tv
Other studio series owners suggest they are based on Samsung T.V;s not sure about the M5400.
A useful contact is the supplier of Studio series TV's in Knoxville Tel : 1-865-694-2704 contact Kelly Green Ext 116 for info
Oct 23, 2008 | Televison & Video
Studio Series 54
If your TV is
Oct 18, 2008 | Televison & Video
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Jan 13, 2008 | Televison & Video
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
