Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Door hinge for mah22400aww
The door was hanging because the plastic door ring broke at the hinges. we bought the replacement plastic 2 pieces that broke and connect to the door hinges. my wife took it apart and the door latch that you pull to open the door came apart and we cant figure out how it connects into the hook that goes into the door latch to get it all together and working again. the hook has a spring for tension and a pin goes through it but the plastic paddle that you pull on has to connect to that somehow, but that is what I can't figure out. thanks for your time if a solution for me is found
5 Suggested Answers
Washer_tech
  • 164 Answers
SOURCE: Front load washer and dryer door change.
nope just swap the hinges, but make sure you turn them the correct way or you'll wonder why the thing won't close
Posted on Nov 04, 2007
canbruce75
  • 1776 Answers
SOURCE: Door broken at hinge area on Maytag front load washer 24".
Try using some J.B. Weld on it instead of glue. It will essential form a weld and should hold up better. You might want to give that a try. Good luck and best wishes.
Posted on Aug 05, 2009
SOURCE: My EPIC MFW9700S stopped working. The lights turn
controls are locked
Posted on Nov 24, 2009
richroth
  • 9472 Answers
SOURCE: My Amana NFW7200TW front loader Washer door is
You need to replace the door. Here is a link to the part you will need.
Posted on Dec 24, 2010
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
Sub zero refrigerators 632 door won't stay closed
Thee is a plastic cam at the bottom hinge of the door. Mine cracked and I bought a new one online for like $30 (for a piece of plastic). Got a strong friend to lift the door off the hinges while I replaced it. make sure you get the right one for left or right doors.
7014663 Sub Zero Refrigerator Bottom Cabinet Hinge Cam LH (7014663) (7014663) - Genuine Refrigerator Parts
Sep 01, 2014 | Sub-Zero 632 / S
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
My side by side refrigerator door swings open (somewhat out of control). It appears that the door stop is no longer working How can I fix this?
There is a self closer stop mechanism under the door between the door and the hinge, The door must be removed by removing the top hinge and lifting off the lower hinge flip the door and you will see a plastic piece which is probably broken there is also a piece on the hinge . Both should be replaced
Feb 27, 2011 | GE Refrigerators
Strange thing over night my refrigerator has lost the suction in the doors. I have to close the door and hold the door close, to keep it close
there is a plastic part that attaches to the lower hinge that helps keep the door closed. it is like a rocker that when the door is open the door rides up on the plastic rocker then as you close the door the door rides down on the hinge rocker and helps to force it closed. mine stopped closing on it's own then all of a sudden the black plastic piece broke and fell to the floor. I am ordering a new piece if I can find the part number.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
I am looking to reverse the door on my Maytag Drayer MEDE300VW. It looks fairly simple, but I want to make sure I do it right. Anyone done one of these before?
My husband just did the same thing today! First, remove all screws except the 4 that require an Allen wrench. There are 3 layers to the door. Separate the layers and remove the hinge. Rotate the middle plastic layer and reattach the hinge to the opposite side. Reassemble. Total time: 15-20 mins. Total sweat and swearing: 0
Dec 01, 2009 | Maytag MEDE300V Dryer
I need to remove and replace my drivers side door and do not know how to do so.
go look at the passengers side. take note of the door seam and fender seam width. its about the width of a piece of cardboad. additionally look at the door hinges on the passenger side. it may or may not have washer shims. if they do/dont then just match up with passenger side. it takes 2 people to hang the door. screw in door hinges "finger tight" just to take off the weight of someone holding the door. play with the hinges until you can open/close door without binding or crimping fender at the seam. do not over tighten hinge bolts until the door opens/closes unobstructed. bottomline 2 people needed. slow and tedious job. you may have to add or take shims(washers) out for good fit. note that you may have to add shims to the inner door hinges or to the fender hinges where they meet. hope this is clear instructions.
May 30, 2009 | 2002 Pontiac Grand Prix
Bolts broke on bottom drivers door hinge
a vw wreckers or dealer will sell you the correct hinge bolts with the year model on you
Nov 08, 2008 | 1998 Volkswagen Beetle
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
