My Canon IP1700 will not print last page first, tho I've checked the box and unchecked it and checked again, it still prints first page first, regardless (ever since I bought it.)
  • 1,124 Answers
Go to your printer preferences and be sure that your configuration is right.
Set the pages as your program allow. For example if you're using MS Word you can set the pages, by number, odds and even or collate. Check the order of your pages at your document.
Be sure about that first.
Go to the menu of the printer (not in the computer) and check the sequence of printing.
If the problem is not related to your program and you think that your printer became crazy
do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Posted on Oct 18, 2008
Always prints from back page to front page can this be changed
The print screen for the printer should have a check box for 'reverse the pages printed'. For some reason this sounds like it is selected. Uncheck the box and you should be able to print from page 1.
Oct 03, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
I can't figure out how to get my Canon PIXMA MX 850 printer to print the last page first and the first page last so that the pages are in order.
In the printing Preferences dialog box, go to the Page Setup tab, and near the bottom you will see an option "Print from Last Page". Put a check mark in this box.
Dec 29, 2009 | Canon PIXMA MX850 multifunction InkJet...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
My canon pixma ip1700 will not print. One page of my document printed and the second page refuses to print.
did you see the indicator light?
i have the same problem and the solution is try to replace the mainboard to a new one.
Jan 16, 2009 | Canon PIXMA iP1600 Printer
Two-sided printing
On a PC...
- Ctrl + p to print
- Choose the Canon MP530 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Duplex Printing
My paper always gets jammed, so I always uncheck the Automatic checkbox. Hopefully you won't have to do that.
Good luck.
Nov 13, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Reversing the print
You can check/uncheck the box "start printing from last page" in : Start - Printers and faxes - Right_Click_PSC1410 - Properties - Printing preferences - Features.
Aug 31, 2007 | HP PSC 1410 All-In-One InkJet Printer
Printing in reverse order
You might have two programs trying to run your printer and they are in conflict. Check your settings in both your "Word processing program" and check under "printer and faxes" on your Start menu or from the control panel. See if they are the same. They should be. Open your word program and print any document using "print" from the File tab. Also look for "print set up" or Page setup". Printer settings can be there too. Click on properties for the printer when it shows you the printer box. Check all your settings. Simplest way is to simnply un-install the printer and let Windows re-install it. Use the new drivers when it asks for it. That should clear it up. If it doesn't it has some other setting I don't know about.
Aug 22, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
104 people viewed this question
