Question about Bose Wave Music System CD Shelf System
CD Player The CD motor spins, but the display reads "No CD."
  • 1 more comment
  • Gar Chanko Jun 13, 2006
    No luck after the cleaning. I can hear the servo motor during startup, but the after a few clicks it stops at track 1 and then displays the (no) Disk message.
  • Narit Thapan Dec 11, 2008
    The CD is junk! I called Bose and they want us to spend $129.00 plus shipping and taxes. This Bose do not want to provided us anything. They are bad like Volvo in 1980 try to captarlized the repair service.
  • Anonymous Jan 18, 2009
    The radio CD plays, but the CD player doesn't == it just says "no cd" even though there are CD's in the slots.
    President:
  • 3,130 Answers
Have you tryed cleaning the laser lens with a lens cleaner?? The fact that it spins tells us that the unit is focusing but not reading the proper data. Good Luck
Posted on Jun 12, 2006
  • Larry  Dillon
    Larry Dillon Jun 13, 2006
    If that didnt help then your problem is most likly a tracking or focusing problem and is not a consermer serveable item, as there are special equipment and tools you need to operate and alighn these pups. Sorry its time to see the repairman or a new one.
SOURCE:
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
Error3 displayed when cd is inside
two reasons why CD/DVD players will not read
1. the optical lens is bad
2. the motor is not spinning at the correct rpm
Feb 23, 2011 | Aiwa CDC-MP3 CD Player
Panasonic DVD-A120U Problem with disc in player
either the laser is burnt out,or the disc motor is no good.
locate the peice that the cd sits on.spin it.if it reads the disc after,the motor is no good.
Sep 01, 2009 | Panasonic Electronics - Others
Spins CD but displays"read " but plays nothing
Hi, this is CD lens assembly failure. the len sits in a lens assembly that has a motor that allows it to travel along a rail. this is how it reads the CD in motion. this assembly has failed and , you will need to replace this mechanism in order for the lens to be able to read once more.
May 17, 2009 | Numark MP-102 CD Player
Technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Oct 07, 2008 | Technics SL-PG480A CD Player
Sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
Jun 03, 2008 | Audio Players & Recorders
CD Player Motor & Laser
If motor is NOT spining, laser can't read CD.
Oct 06, 2007 | RCA RS2503 Shelf System
Player reads no disc
try to clean the lens use coton and water. do not use cleaning disc.
Sep 17, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
Bose Wave Music System CD Shelf System Logo
247 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
